Old 08-11-2010, 03:13 AM
Punch Drunk Punch Drunk is offline
Default blinking 1394 light on 002r
i have dual boot system, i do not use the xp side for anything but pro tools, simply because i cannot for the life of me get it to run on vista. i dont want help with that, ive given up. in any event, on saturday, i recorded a few songs, everything was fine, i restarted into vista, went about my business. today i booted back into xp to record something, the entire computer is laggy. pro tools buffer errors, cant bounce tracks without errors, etc. i deleted preferences and tried that, now im able to record for about a minute..but still cant bounce songs. all while this is going on, the 1394 light blinks now and then. sometimes itll be solid for the session then flicker a lil bit, then when i exit pt it blinks non stop.
i honestly just dont understand what could happen in a few days, when i did nothing to any of the software on the xp drive. its on a completely separate drive, and it wasnt booted into since saturday. the vista drive doesnt have viruses, i dont install anything into the xp drive from there, nothing.
anyone have any ideas?
also, what is the fastest affordable ($200-300) processor out right now? i may just buy a new mobo, cpu, and ram, and jump to windows 7 now that pro tools finally decided to support operating systems during its active lifespan.
Old 08-11-2010, 10:07 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: blinking 1394 light on 002r
Forgive me if I'm stating the obvious, but have you rebooted, tried reinstalling the Digi drivers and/or Pro Tools, try a system restore or restoring XP from a backup image? It's impossible to know what's changed to cause PT not to run properly without a bit of troubleshooting. Could even be that some hardware has failed. As far as affordable processors - check out the I7 sticky, you won't be disappointed!
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (3)
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-11-2010, 11:46 PM
shortly after this post when i booted back into xp i had a chck disc run pop up and apparently invalid security id's for about 80,000 files needed to be replaced with the default keys. i used the manufacturers tools to check the drives and it says they are fine, and all of my data is backed up, im just going to try to install it on vista again, and if all else fails, just reinstall xp. im just worried if ill have to redo the boot options since it's dual boot.
thank you for the suggestions though, i figured it might be the i7, how is pro tools functioning on windows 7 so far?
Old 08-16-2010, 01:13 AM
after many times trying to reinstall windows, even though many checks said it was fine, i've concluded the hard disc died. luckily, my machine has 4, one of which is a back up everything, so i moved some stuff around and put xp on one of the other drives. everythings fine now.
still looking to upgrade to windows 7/i7 tho, and the 1394 light is also still blinking even tho pro tools works fine,
1394 front light should be blinking or steady? JSOM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-09-2012 03:35 PM
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
Blinking 1394 Light? kcarkeet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 01-12-2008 06:36 PM
1394 light blinking on and off on my rack?!? help! chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-12-2006 10:31 AM
is your 002r 1394 Light Blinking? Read this... gibson_sg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-20-2005 09:57 PM
