Reason 4 and Pro Tools LE 7.4 Rewire crash
Whenever I try to use Reason 4 with rewire, it crashes. In my previous post I said how my motherboard isn't supported, so Check that for specs. I'm running 7.4cs9 and I do open reason Before I use the inserts/sends for rewire. Pro Tools gives me a Access Violation error and I get the "Pro Tools encountered an Error and must close" with the send error or don't send error to Microsoft.
Anyone got any help? Thanks. |
Re: Reason 4 and Pro Tools LE 7.4 Rewire crash
I don't open Reason before inserting it. I let the insert open it! Try that. But isn't the lack of motherboard support a possible answer to your question?
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
I got pro tools to work 100% with my motherboard although it is not supported. Reason is fine by itself, just not in Rewire slave mode.
I have this exact same problem.
Reason 3.0 with ProTools LE 8 on an 003 Rack. The system is a Creation Station from Sweetwater and everything is supported by Digi's PC hardware requirements. Reason works fine. As soon as I fire up an Instrument insert with Rewire to Reason, the program crashes out. Clean Windows Vista Home Premium install, clean ProTools install (both Vista and PT8 installed and setup by sweetwater techs, so it's already properly configed) and a clean Reason 3 install. |
(introduced with) Vista has a feature called UAC, it blocks anything from accessing kernel. If you want PT to run with rewire (which accesses kernel) then you should:
a.) right click on host daw (PT8, Live 8, Sonar, ect) and run as administrator (psw required) b.) turn off UAC (located in contral panel/users and groups) good luck |
REWIRE Pro Tools 8 with Reason 7 | brian crain | macOS | 5 | 02-05-2014 02:43 PM |
Pro Tools 11 and Reason 7.0.1 with Rewire | DonaldM | Pro Tools 11 | 0 | 08-15-2013 01:20 PM |
Help Please! Pro tools 8, Reason 4 rewire | Colin_09 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-31-2010 10:06 AM |
Help for Pro Tools/ReWire/Reason | Fern514 | Pro Tools M-Powered (Mac) | 3 | 09-16-2008 05:00 AM |
Crash Crash Crash Live 6 Pro Tools Rewire | TimmyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-12-2007 11:26 AM |
