Old 03-11-2009, 08:42 AM
nickair nickair is offline
Default Start power mac with power switch
I have an old PowerMac G4, running MacOS 9.2. I use it to run ProTools, with an external PCI chassis and several external AD/DA converters. I would like to power up everything using one power switch. How can I make the PowerMac turn on and start when I switch the power switch?
Anybody knows how to do that?
Thanks
nickair
Old 03-11-2009, 08:46 AM
C C is offline
Default Re: Start power mac with power switch
Just noticed you are OS9
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 03-11-2009, 10:16 AM
bpert bpert is offline
Pretty sure that you can't in any conventional way. Just reach over and turn that puppy on. I don't know if it's the same for your system but I turn on my hard drives first, then MIDI gear, then interface, THEN my computer. So I don't really see the need for one switch that turns on everything anyway.
Old 03-11-2009, 12:16 PM
ThomasPMusic ThomasPMusic is offline
Just go to energy saver in preferences and select auto restore power after ...
I can't remember the exact lingo, but I used to have my mac set to automatically restore power after a power failure. This means the mac will start up whenever it is connected to power.
tp
Old 03-11-2009, 01:28 PM
peterle peterle is offline
one power button can make problems when you use
a pci chassis. The chassis have to be switched on
before the computer. If not it can be that the cards inside
the chassis are not recognized.
Why dont you use a power button for the peripherals and use
the boot button on your (hopefully older) mac usb-keyboard?
regards
foley artist , soundeditor
Power switch on my PC failed Terry Wetzel Pro Tools 9 15 12-27-2012 08:50 AM
Switch to 10.5 on a Power Mac G5? Larry G Pro Tools TDM Systems (Mac) 3 09-15-2008 06:15 PM
Power switch? eidschun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2008 01:32 PM
Why no power switch on the MBox Pro? frienddragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-20-2008 03:35 AM
003 Power Switch ProdGawd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-23-2008 04:00 PM
