Midi editing question
I have a MIDI groove from EZ Drummer that has a foot close hi-hat in the drum groove that goes through the entire selection....... in 1/8th notes...... and I want to remove and change it to a regular stick hi-hat groove of my own choice. It is 16 bars of what I'm using as a a pre-chorus- so there are a bunch of them.
How can I select all of them and delete them or drag them all to the correct placement together? Or do I have to laboriously click on each one in the MIDI Editor to delete or drag them? The same can be said about velocities. I know how to set the default MIDI note velocity. But say I have a bunch of hi-hat or other notes, kick drum say.... that are too low in volume and I want to change all of the velocity values to a higher number and then play with different velocities later, for a more natural sound. Can I do them all together or have to edit each one at a time? I tried highlighting the open hi-hat as mentioned before and hitting delete but that didn't work and I'm have the devil of a time trying to search out this info. Probably basic MIDI editing 101 but your help will be appreciated. Thanks.
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Re: Midi editing question
Fairly easy to remedy both situations. Open the MIDI track in the MIDI editor and click the piano key (this selects all the incidences of that note) on the left side that corresponds to the note that plays the closed hihat and drag it up or down to the note that corresponds to the cymbal you want to use. Or use the transpose function to move the note. Right click on the note and select 'event operations' and then select 'transpose'. Same thing for the velocity - select 'change velocity'. This will change all the velocities at once. Pay attention to the options in the change velocity box as there's a way to randomnize them.
Once you have selected all that note, you can delete them, or you can change track display to velocity, and then you can drag the velocity marks of all the notes at once. Or you can use the MIDI control panel window (option + o I think) and change all the velocities by a certain value, or set them all to a specific value. |
Thank you very much folks.
MIDI editing question. | Thenewexhibit | Pro Tools 2020 | 2 | 07-31-2020 09:36 AM |
MIDI Editing Question. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-07-2010 08:03 PM |
MIDI editing question | ivet | MIDI | 1 | 09-03-2008 09:55 PM |
MIDI Editing Question - Converting BPM | shendrie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 05-16-2003 10:04 PM |
MIDI Editing Question | markmcc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-27-2001 12:30 AM |
