Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 04-18-2024, 12:57 PM
dcoffset dcoffset is offline
Default Atmos Binaural Live-Re-Render Monitoring
I'm using the Internal Atmos Renderer, and have noticed the binaural renderer seems to be inconsistent with its loudness monitoring. Some passes report no peaks and others report peaks when nothing has changed in the mix.
This seems kinda weird, and a pain when trying to prevent peaks from hitting the Atmos in-built limiter. The track I'm currently working on also seems consistently louder in binaural than the 2.0, which is also a bit weird but may be explained by the EQ/phase shifts from the HRTF process...
Any insights on this would be appreciated!
SYS 1: MacBook Pro M1 Max 64Gb / OSX Sequoia 15.1.1 / PT2024.10.1
HW 1: UAD X8 / S3 + Avid Control
SYS 2: TrashCan Intel 64Gb / OSX Ventura / PT2024.10.1
HW 2: DAD AX32 (pre-MTRX) / SSL AWS Delta
Old 06-13-2024, 10:47 AM
bozmantate bozmantate is offline
Default Re: Atmos Binaural Live-Re-Render Monitoring
Did you ever figure this out?
I've just mixed a feature in Amos using the internal renderer and the Binaural render is coming out some 8-10 dB higher than the 2.0 render
Old 06-13-2024, 12:35 PM
Oddly enough, I recently asked Dolby the question in a seminar and they just announced changes in the latest update Dolby Atmos Renderer update.
Not sure if this is relevant in an RMU setting [altho would assume it would be applied across Dolby products], so things may depend on your setup...
issue with Atmos re-render downmix controls Protone Post - Surround - Video 17 04-21-2025 10:23 PM
Dolby Atmos Render CPU on macOS shawnhonsberger Pro Tools | MTRX & MTRX Studio 8 01-04-2024 03:46 PM
Dolby Atmos Render to MP4 ziggy2282 Pro Tools 1 12-20-2023 05:42 PM
Integrated Atmos Renderer Binaural Shortcomings Tone_Mechanic Pro Tools 3 12-15-2023 08:08 AM
is there any way to render dolby atmos within the same windows computer? reynerferdinand Post - Surround - Video 0 08-03-2021 01:25 AM
