EUCON Midi MCU not working on M1 Mac
I'm using an Avid Artist Mix with an M1 MacBook Air.
Using the latest Big Sur Eucon 4.3.8.29 Eucon and the artist mix work great with Pro Tools, but I've been unable to get Eucon midi to work as an MCU device with other DAW's either ones running through natively or through rosetta. (REAPER, Ableton, Bitwig) The DAW software will all see the Euphonix virtual midi ports and I can connect to them in midi preferences but when I set them up it doesn't do anything. I'm following the setup guide and have also successfully gotten this working in the past on a number of different Mac and Windows workstations but no luck here. I've tried full uninstall wiping Eucon preferences and reinstalling, removing all mackie applications and re-adding them.....A couple times Bitwig and Ableton will recognize and work briefly but then stop and never start working again after restarting the DAW. I'm wondering if anyone else has gotten Eucon MCU working on an M1 Mac? If this is a known issue or something anomalous with my system. Would love to get this working. If anyone has any insight or suggestions on something to try please let me know. thanks |
Re: EUCON Midi MCU not working on M1 Mac
This was tested working, if you can see the MIDI ports then the driver has loaded Ok.
Hey thanks
So you are saying this as an issue with the DAW's I've tried that haven't recognized it correctly? Or a problem on Apple's side? Is there a potential conflict with other hardware? I'm fairly certain I've installed everything correctly. I've tried to reinstall.... and when I've done this in the past it's always worked on other systems. |
Working with several EuCon hardware | Mark Ziebarth | Artist Series | 5 | 04-28-2021 10:31 AM |
eucon midi not working (OSX) | hd2010 | Artist Series | 6 | 10-22-2017 01:58 AM |
Eucon 3.1.3 is the last version working on OSX 10.6.8 | jacko | Artist Series | 1 | 04-24-2015 12:17 PM |
Eucon not working with 11.1.3 | Frank Kruse | Artist Series | 11 | 05-20-2014 09:41 PM |
Euphonix EuCon 2.5.2 - Pan Not Working | Carl Sealove | Pro Tools TDM Systems (Mac) | 3 | 01-20-2010 07:04 AM |
