can\'t hear guitar
hey there , i'm not sure of what i did but i can only hear my guitar when track is record enabled and i can't rehearse cause when i hit play i don't hear it either ,,, the only way i can rehearse is to record the track and then undo record until i'm comfortable with what i've played . i used to be able to hear what i was playing without recording it , any suggestions???? thanx
Re: can\'t hear guitar
Switch to input only monitoring(Alt-K I think) or add an aux track set to the same input and monitor your guitar from the aux track until you are ready to record. If you record and don't like what you did, when you hit STOP, before you do anything else, hit ctrl-z and your new audio will disappear like it was never there. This trick is handy when punching in because it will put you exactly where you started to do the punch-in again.
hey thanx a bunch the aux track worked great but i could have sworn that i played to what was already recorded before i recorded what i was playing ,, in either case the aux track did the trick .... thanx again
This isn't just a guitar thing - right? When I record multiple tracks, the same situation occurs & I basically record the tracks & then hit the cntrl z thing & they disappear. I've always thought that the process was a bit backward - that you should be able to play the tracks back & hear the input of the new track (guitar or whatever) without actually recording it.
dont want to hear guitar amp while recording | Sushidude | Eleven Rack | 9 | 09-04-2011 01:41 PM |
I hear either the drums OR the guitar | aehn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-07-2010 01:01 AM |
Cannot hear guitar unless I record | Fran Amsterdam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-06-2010 05:04 AM |
Can't hear guitar/Can't get signal to software | Floyd Wills | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-16-2008 09:21 AM |
Can't hear guitar on playback only in record..... | northwinds | Pro Tools M-Powered (Win) | 1 | 10-29-2007 07:39 AM |
