Old 03-05-2007, 10:52 AM
DavyDevil DavyDevil is offline
Default Laptop Spec
Hi Folks,
Just got a spec from Dell for a laptop to run with Pro Tools LE 7.1 with Mbox 2 Mini.
I've checked the compatibility page and all seems ok, but if any of the more experienced posters could double check for me, it'd be super!!!
Thanks!!
Dell Inspiron 6400 Duo Processor T2250 (1.73 GHz, 533 MHz FSB 2 MB L2 cache)
Memory Dual-Channel 1024MB (2x512) 533MHz DDR2 SDRAM
Graphics Card ATI Mobility Radeon X1400 256MB with TV and S-Video Output PCI-Express x16
English - Genuine Windows XP Home SP2
Firewire connection
Hard Drive 80GB Serial ATA (5400 RPM)
Cheers again for any help or advice!
Davy
Old 03-05-2007, 12:22 PM
Panoramical Panoramical is offline
Default Re: Laptop Spec
The hard drive is not quick enough (or big enough!)...you'll need 7200rpm rather than 5400rpm.
Old 03-05-2007, 12:30 PM
surely speed makes no difference if i'm not recording to the system drive?
Old 03-05-2007, 12:54 PM
TheHenchman TheHenchman is offline
it certainly makes a difference for playback.
Again, don't expect any firewire audio devices to work properly, as the Dell laptops have firewire issues.
www.markhensley.tv
IMDB Credits
Old 03-05-2007, 12:59 PM
Any more info on this?
Do USB 2 external drives work?
Old 03-05-2007, 01:05 PM
There have been may people reporting issues with Dell notebooks related to the firewire implementation. Some have it working while other are pulling their hair out over it. USB 2.0 is not recommended by Digidesign for audio drives but some also have this working. Firewire has a higher sustained throughput than USB 2.0. Look at the top of this forum for a sticky thread about which notebooks are certified with Protools (both are HP's).
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6.2 running Protools 2021.12
Old 03-05-2007, 01:10 PM
thanks dragon
hows about buying a decent PCMCIA firewire card? Do the trick?
Old 03-06-2007, 03:17 PM
thanks dragon
Get an HP Core 2 Duo laptop.
www.markhensley.tv
IMDB Credits
Laptop spec skiffle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-10-2010 12:48 PM
This PC spec OK? scardanelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-19-2009 01:16 PM
Laptop spec for recording ADR King of Spain Post - Surround - Video 4 10-07-2008 02:48 AM
RTAS spec? scratcher_x General Discussion 0 07-18-2005 05:02 AM
Min spec Mac for PT 6? poppy Pro Tools TDM Systems (Mac) 0 01-02-2004 01:53 PM
