Old 11-22-2021, 09:30 PM
rogerwilco2000 rogerwilco2000 is offline
Default Pro Tools with Apple/iPad Sidecar
If you're using a Mac and and iPad there's a feature called Sidecar which will turn your iPad into a secondary display which can either mirror or extend your main computer's desktop.
When I use this with Pro Tools, moving a PT window from the main to the Sidecar display turns Pro Tools unresponsive and I have to force quit.
Has anyone else run into this issue and is there a fix? I've searched the internet and the only thread I could find was an old one on Reddit where everyone chimed in how their normal secondary monitor worked just fine. For the record, a standard second monitor works great; it's just a Sidecar display that freezes PT.
I'm on an M1 mini (Big Sur on Silicon/Rosetta), most current PT install.
Old 11-23-2021, 09:25 PM
audiobob's Avatar
audiobob audiobob is offline
Default Re: Pro Tools with Apple/iPad Sidecar
I use Sidecar with an iPad but only as a movie playback monitor for sound design and mixing. Works perfectly with no PT freezes on an Intel Mac mini with Big Sur.
Old 11-24-2021, 04:07 PM
Thanks for this. I can remember using Sidecar with my older Intel i7 MacBook Pro; I'm assuming this is probably a Silicon compatibility issue and not a Sidecar one.
Old 11-24-2021, 05:55 PM
jeffro's Avatar
jeffro jeffro is offline
Haven't used it much, but some quick tests with Pro Tools Ultimate 2021.10 on a 2019 iMac (Catalina or Bug Sur) with an iPad Pro didn't show any problems.
Izotope Insight 2 not working on iPad screen with Sidecar or Duet? randolphschwiemerfield AAX Plug-ins 3 09-19-2021 04:45 PM
Apple Ipad tablet unveiled nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-21-2010 06:23 PM
