Old 12-10-2014, 09:26 AM
americanslidol americanslidol is offline
Default Presets Not Showing Up
So, since I reinstalled PT 11, none of the plugins that come with PT11 are showing any presets. I've tried, per the sweetwater knowledge base's advice, I've tried deleting the PT folder from my "documents". I was GOING to try moving the plugin-settings folder from "documents" to the desktop and Launch Pro Tools 11 where a new Plug-In Settings folder would be created, so that I could quit Pro Tools, and move the contents of the Plug-In Settings folder now on the desktop to the new Plug-In Settings folder in Home/Documents/Pro Tools. that would've supposedly restored any presets from the previous install after launching pro tools again. But, after following the Sweetwater advice, the pro tools folder is not to be found in my documents folder. I've restarted the CPU (macbook pro) and Pro Tools runs fine--just without those presets.
Any advice, PT gurus?
Old 12-10-2014, 10:00 AM
Oliver M Oliver M is offline
Default Re: Presets Not Showing Up
Check the path to your PT library folder:
Pro Tools Preferences/Operation Tab/User Library
at the bottom left.
Old 12-10-2014, 10:15 AM
at the bottom left.
That path leads to my external HDD, where I save/record. Should I be doing something in regard to it?
Old 12-10-2014, 10:27 AM
at the bottom left.
Ah! I see. I got it. Thanks!
Old 12-12-2014, 05:58 PM
Old 10-07-2015, 04:24 PM
Billair's Avatar
Billair Billair is offline
at the bottom left.
sorry this is old but i am having the same problem only i don't get it ? i checked the path via pt prefs and it goes to documents pro tools plug settings etc only there are no presets, my had presets are there and thats it, when i click on plugin settings it has infinite amount of empty folders.... i too did the sweet water thing but have done a clean install since
Waves plugins resetting, and presets not showing logocomic Pro Tools 10 9 01-29-2015 10:29 AM
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets headsup macOS 4 12-17-2011 01:28 PM
Hybrid not showing presets with Snow Leopard update jackshocklee Virtual Instruments 15 02-17-2010 04:26 PM
at times plugin presets not showing digidesigner VENUE Live Sound Systems 2 11-29-2009 12:33 PM
Plugins presets not showing francois Pro Tools TDM Systems (Mac) 1 09-15-2005 09:06 AM
