Old 12-25-2011, 02:30 AM
dstryrwiz dstryrwiz is offline
Default Does The Firewire Cable Cause Differences In Quality?
This probably has already been discussed, but does the firewire cable cause a perceivable difference in quality besides working and not working? I know this a huge debate for many other types of cables including 1/4" cables, XLR cables, IEC cables, and others, some people believing some cables having an effect, other people saying there is none. If anyone here knows of any differences for firewire cables, what cables can you recommend? Thanks!
Old 12-25-2011, 03:39 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: Does The Firewire Cable Cause Differences In Quality?
The main difference in Firewire cables is the quality of the builds.
There's no real difference in performance between cheap firewire cables and expensive firewire cables, but better quality builds will be less prone to failures and will most likely have better longevity.
The firewire cables included with the 003 are bottom of the barrel in terms of quality builds.
That said, I used mine for years with my 002/003, and never had a problem.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 12-25-2011, 03:43 AM
clausiii's Avatar
clausiii clausiii is offline
no, there is no audible difference, just working or not working. It transports digital stream, that´s all. Audio cables in the analog domain do influence sound.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 12-25-2011, 06:14 AM
panamajack's Avatar
panamajack panamajack is offline
I like the FW cables protected by the silver, wire-mesh braid. How the wire itself is connected to the plugs has to be somewhat important, so a brand name probably has higher quality standards.
better quality power cable = better quality sound? dbvoyager General Discussion 22 04-15-2012 06:08 PM
the quality of your firewire cable DOES matter billynojokes Pro Tools 9 2 07-26-2011 09:56 AM
Optical cable quality differences ??? gtrplyr1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-2004 06:09 AM
Differences in recording quality between LE and HD Johnny916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-18-2004 10:26 PM
RTAS MAS & VST Quality differences? Steve Rieck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-31-2002 05:57 AM
