Old 08-05-2022, 08:43 PM
janmuths janmuths is offline
Default HD Omni - Analog out question
Hi all,
I’ve got an Omni and would like to use the DB25 for 8 analog outs. In the hardware setup, I can set outputs 3-8, no problem - but 1-2 always defaults to Monitor. The manual says the monitor path is always there and cannot be changed… Does that mean I cannot route signal to the db25 out 1-2?
Am I out of luck here, or has anyone found a work-around maybe?
Thank you.
Sunny Vibes from Byron Bay, Australia
Jan ‘Yarn’ Muths
www.mixartist.com.au
2010 Dolphin Award for Production / Engineering
AVID Certified Instructor
Old 08-05-2022, 10:08 PM
BScout BScout is offline
Default Re: HD Omni - Analog out question
Go to the monitor tab and delete the assignments and then they become available
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Old 08-05-2022, 11:54 PM
Thank you. I thought I had tried that, but maybe I’m wrong.
Thank you, I’ll try that one more time, cheers!
Omni to C24 Analog 7-8 KGraham045 ICON & C|24 0 08-23-2016 07:14 PM
Question about db25 analog out on the Omni. Dave S. Pro Tools HDX & HD Native Systems (Mac) 12 05-21-2014 09:52 PM
+4 dBu or -10 dBv analog in Omni chrisdee Pro Tools HDX & HD Native Systems (Win) 2 10-07-2012 04:15 PM
Are Omni Analog ins calibrate-able? Picture Start Pro Tools TDM Systems (Mac) 7 10-07-2011 08:07 AM
01V 18bit analog omni outputs? east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-07-2001 08:26 PM
