Old 07-29-2022, 04:29 AM
mnstudio mnstudio is offline
Default SPOT Mode enabled: clicking on a clip it disappears...
Just updated to PT 2022.7.0
Now: SPOT Mode enabled, if I click on a clip it disappears...
Help please
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 07-29-2022, 05:31 AM
XJENSEN XJENSEN is offline
Default Re: SPOT Mode enabled: clicking on a clip it disappears...
Did you buy the Magicians edition of Pro Tools?
Old 07-29-2022, 05:43 AM
What does it mean? On 2022.6 it worked fine
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 07-29-2022, 10:50 AM
BScout BScout is offline
Do you have autospot on?
If so, turn that off (auto spot is different from just Spot mode; autospot is an option under the Options menu.) Autospot can throw your clips to the end or very beginning of the timeline (which makes it "disappear")
Pro Tools Ult 2022.7, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 4TB, GPU GTX 980 4GB
Old 07-30-2022, 12:22 AM
It's as you stated.
Thank you so much
I have to understand why it had been converted to auto-spot ON seeing that I hadn’t used this option before. Maybe with the update…
And also I wonder which is the usefulness of that option
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Old 07-30-2022, 03:58 PM
Originally Posted by mnstudio View Post
It's as you stated.
Thank you so much
It's a kind of old school system. You have to be feeding Pro Tools a positional clock source.
Its name doesn't make any sense today. And I wonder if anyone even uses it.
Meanwhile, we've been asking for an actual auto spot feature but Avid has not delivered (though it exists in Media Composer -- that's right, the video NLE has it but he audio DAW does not)
Old 08-01-2022, 12:41 AM
Thank you so much
MUSICNET STUDIO
Via Puini, 97
57128 Livorno
ITALY
Source Clip disappears from clip list after separating bigdoghat Pro Tools 17 06-11-2022 02:59 PM
Waveform volume display inside a clip disappears [SOLVED] firmflange Pro Tools 12 2 10-28-2016 10:23 AM
ProTools Edit Window Disappears With Soundminer Spot to Timeline chadjhughes macOS 1 02-25-2014 06:51 AM
Grid mode, shuffle mode, spot mode and slip mode. RogTaylor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-24-2010 10:30 AM
Spot mode bug? Brave Noise Pro Tools TDM Systems (Mac) 2 02-24-2002 12:02 AM
