Old 04-11-2012, 12:32 PM
Sf Audio Sf Audio is offline
Default pro tools 8.0 installation question
I have PTLE 8.0.1, which says win xp/vista. I want to get the upgrade to 8.0.5 and use it on win 7.
Can I install 8.0.1 on win 7 and then run the updater? How does this work?
Thanks
Old 04-11-2012, 02:57 PM
solidwalnut's Avatar
solidwalnut solidwalnut is offline
Default Re: pro tools 8.0 installation question
Please wait until you receive confirmation that this is true, but I believe the answer to be that you can install v8 on the W7 OS platform, but do not operate it. After you've installed it, THEN install the v8.0.5 upgrade before operating.
Worship Leader * Producer * Guitar Man
Intel i7 3930k CPU, Gigabyte GA-X79-UD3 MB, G.Skill 16GB (DDR3 1600) RAM, WD Caviar Black 750GB HD x4
Neve 5043 Comp * Manley Dual Mic Pre * Apogee Rosetta 200
Eleven Rack (live rig and studio rig!!)
Win7 * 003R * PT 11
Old 04-11-2012, 07:26 PM
arkitek1 arkitek1 is offline
Yes you can. I recently abandoned an old Media Center computer running XP and did a new 8.0.1 install and updated to 8.0.5 on my new Toshiba laptop running Win 7 ultimate. It works great for my home hobbiest needs and I can now run an external USB recording drive which I could not not do on XP. Go for it.
Old 04-13-2012, 02:24 AM
zedhed's Avatar
zedhed zedhed is offline
That is what I did and it worked fine.
Install both with your interface switched off, once updated reboot with it switched on.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 04-13-2012, 06:34 AM
Tom Kruse Tom Kruse is offline
Sounds good, but when I try to install 8.0.3 on my new W7 OS machine, it just sits there. any suggestions on how to get it to install? I'd gladly then run the 8.0.5 update.
Tom
Old 04-13-2012, 06:58 PM
I went straight from 8.0.1 to 8.0.5.
Old 04-14-2012, 12:18 PM
Tom
What worked here on my laptop is; install 8,0,3 in Vista SP1 comparability mode, and DO NOT connect the interface when asked(just click OKAY and let it finish and reboot. Next, run the 8.0.5 updater and DO connect the interface when asked. Once the installer finishes and reboots again, right-click on the PT icon and select the Compatiblity tab. Check the boxes for Always Run as Admin, and Disable Desktop Composition. Cross your fingers and open PT(have your authorization code handy...the one that starts with "DIGI08.....")
Pro Tools 11.0.2 Installation Question heavyd1176 Pro Tools 11 1 09-22-2013 11:40 AM
Pro Tools Installation Question croomraider Pro Tools 10 1 06-25-2012 09:00 PM
Question for new installation of Pro Tools 10 scottee Windows 1 04-16-2012 07:09 AM
Installation Problem - "A Pro tools installation has been detected on you computer" Nikkimac7049 Pro Tools M-Powered (Win) 2 02-10-2012 07:02 PM
pro tools le 7.3 installation question track monkey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-20-2007 09:44 AM
