Old 08-14-2006, 07:29 AM
Torchlight Torchlight is offline
Default PRO TOOLS SCREEN FREEZES INTERMITTENTLY!
Hi everyone!
I have a strange problem ocurring where my Pro Tools screen freezes (level meters, playback cursor, transport display numbers, etc.)? It's wierd that it only happens every once in a while. It's intermittent. I don't know what causes it. What's really wierd is that when it does happen it DOES NOT do anything to the audio either being played or recorded. The audio is never interrupted. It seems to pause (freeze the screen) but I still hear the audio being played or recorded. Then after a few seconds (as long as 8-10 seconds) the screen becomes "live" again and prints the audio that was played or being recorded as if no freeze took place. What this tells me is that the freeze is only affecting the display and not the audio. I don't know if this is normal but I really don't like it at all. It's quite annoying. For instance, it makes is tough to set levels for recording when the level meters freeze up. The other night I was doing some recording and while I was trying to set record levels they kept freezing up on me.
Does anyone know what this is and how it can be fixed? I hope that it's not my iMac. I am using an iMac Intel-Core Duo 1.83 Ghz, with 2GB RAM, and running Pro Tools 7.1.1.
Thanks,
Torchlight
Old 08-14-2006, 08:35 AM
DigiTechSupt's Avatar
Default Re: PRO TOOLS SCREEN FREEZES INTERMITTENTLY!
Do you have all your energy savers turned off and processor performance set at 'highest'?
Have you tried all the steps in the OS X Setup and General Troubleshooting thread yet?
Avid Audio Tech Support
Support FAQ
Old 08-14-2006, 09:31 AM
Hi Digi Tech Support! Thanks for the reply. My energy savers have always been off. I did have my screen saver feature turned on but I have since turned that off too. I did a session for about 5-6 hrs yesterday with the screen saver off and did not witness the problem again. Could the screen saver have been causing this kind of a problem? What are the chances that this could be a problem with my iMac or my Digi002 Rack interface?
I just downloaded the General Troubleshooting post you recommended. What do you mean by proceesor performance to the highest? Do you mean from within Pro Tools, like the CPU Usage limit?
Torchlight
Old 10-15-2006, 10:22 PM
joshdavis20 joshdavis20 is offline
I am having this same exact problem running ProTools HD 7.1cs8 on a G5 dual 2GHZ HD 3 Accel system. It sucks and I am looking to find an answer.
Josh Davis
Audio Engineer
Charlotte, NC
iMac 2.66GHz Intel Duo with 2 GB RAM
Mac OSX 10.5.5
PT LE 8.0
002 with NS-10s and a sub
Random freezes using Pro Tools 9 on new Macbook running Lion OS (blue screen editing) pabloprieto2002 Pro Tools 9 9 08-11-2012 06:40 AM
Music Production Toolkit & Pro Tools LE 8 freezes at loading screen philbagg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-25-2011 07:05 AM
Pro Tools 8 freezes at "Dae Loaded" screen neset46 Pro Tools M-Powered (Win) 22 11-16-2009 07:57 PM
edit window & timecode freezes intermittently zerovu Pro Tools TDM Systems (Mac) 1 06-15-2006 08:12 AM
HELP! Screen Freezes (just screen) While Running 6.1.1 on XP Home Brentsky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-27-2004 08:54 AM
