Old 04-09-2006, 10:00 AM
jonathan jetter jonathan jetter is offline
Default looking for a Dual-Core configuration that WORKS
im putting together a new PC to run PTLE7.
it needs to be dual core....and it needs to work.
none of this hardware buffer error nonsense. and no switching back to single-core mode.
does anyone have a system that's been working great for them? if so, please post the specs...
thanks,
jonathan jetter
Old 04-09-2006, 10:18 AM
wwicklund wwicklund is offline
Default Re: looking for a Dual-Core configuration that WORKS
Simple
Its called a Macbookpro. The machine just screams! Faster than any PC I have seen
Or wait a little while until the Mactel towers come out.
If its windows you want, you can run PT in windows on a Mac Via the new Bootcamp.
Old 04-09-2006, 10:51 AM
RTPro RTPro is offline
Specs below.. mine works great
ABIT AMD Mobo
CORSAIR 2GB RAM
NVIDIA GeForce FX5500
AMD 64 X2 3800+ Dual Core
Seagate 80GB + 250GB 7200 RPM
WIN XP Pro - Digi 002R - PTLE 7.0
Old 04-09-2006, 10:57 AM
Silvermodak Silvermodak is offline
They should all work with 7.0 Ive now realised. I need to upgrade to a 002 to get mine working
Old 04-09-2006, 10:58 AM
Rammelt Rammelt is offline
I have a Dell 5150C.
Noisy but works very well for such a compact little PC.
Best Regards,
John
John Rammelt
Producer / Composer / Post
Hajp AB
old site:
Soundfactory JPR
Old 04-10-2006, 12:31 AM
gerax gerax is offline
Mine has been working rock solid under PT7 for about a month now; no DAE errors of any type, just plain power and ultrafast response even at heavy plug ins loads on a full 32 track session.
Specs:
Asus A8V Deluxe (VIA K8T800 Pro)
Athlon 64 4400 Dual Core
2 x 512Mb DDR400 PC3200 Corasir 2.5 Cas Latency Ram
Zalmann CNPS700CU CPU cooler (silent)
Enermax 350W Silent power supply
Matrox P750 Triple Head video card
Maxtor 80Gb P-ATA system drive
Plextor IDE DVDRW
Yamaha SCSI CDRW
Lacie Firewire PCI controller (for the 002R)
Adaptec 2940 SCSI controller (for the SCSI burner)
Promise Ultra 100 TX2 IDE PCI controller (for the removable audio drives)
Win XP Pro SP2
Pro Tools LE 7
Digi 002R
May add a S-ATA drive for storage and video files down the road (the board has the S-ATA controller built in) and 1Gb more Ram, but so far the system (once XP has been tweaked) is rock solid, no crashes or hangups in my daily 9-10 hours straight sessions, and has been fine since the beginning.
The chipset that's on this Asus model is proven and tested, however in the "Best Desktop" therad you'll find that the motherbard listed is the Asus A8N SLI, which uses the NForce4 chipset; it's fine too, but the SLI chip is not compatible with UAD or Powercore cards in case you would want to use them. It's also PCI express, so be sure to have a compatible video card.
Hope this helps
L.G.
Old 04-10-2006, 01:51 AM
neatguys neatguys is offline
mines for sale works like a charm
http://duc.digidesign.com/showflat.p...fpart=1#985535
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Old 04-10-2006, 02:03 AM
ejwells's Avatar
ejwells ejwells is offline
three words: Best Desktop Thread
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
What configuration works best? protoolsuserman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-06-2009 01:05 PM
Best PT/Windows XP configuration for my PC (4gb/Dual Core) Rukas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-30-2008 11:13 AM
Single core vs. dual core vs. quad core John Peeples Tips & Tricks 9 11-07-2007 03:28 PM
AMD Dual Core Optimizer and WinXP SP2 Dual Core Hotfix PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-10-2007 08:29 AM
help-Pentium 4 configuration that works with digi001?? thestrong@hotmail.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 09-23-2001 08:43 AM
