Old 04-04-2003, 02:49 PM
Placersweet Placersweet is offline
Default 6.0.1 updater problem
I've downloaded the protools 6 update.(6.0.1)
I'm running OS 10.2.3 with a digi001
My problem is that soon as I click install the progress bar only makes it a little ways and gets stuck on "searching my drive" it says 134 items remaining and it just stays there as the mouse arrow spins around. I've left this for a good three hours seeing if it would work itself out but it doesn't and it forces me to restart.
I've just updated to 10.2.4 (which i didn't want to do)
And that didn't solve anything either. I've also tried disk copying the mounted disk and then installing and that didn't work either. I've also tried dragging the files out of the mounted drive onto the desktop and then tried installing from there but no luck with that either.
Any help would be appreciated!
thankyou
Old 04-04-2003, 03:20 PM
guitates guitates is offline
Default Re: 6.0.1 updater problem
How did you download...Sounds like the download is corrupted...Try it again...19MB...
I used Internet Explorer/DSL and it works great... [img]images/icons/cool.gif[/img]
I Seek the Holy Light...
Isaiah 40:31
72 Strat with single 2-Blade pickup
PTLE 10.3 LE
2-SSL Alpha Channels - 1 SSL G-Compressor
Apogee Rosetta 200 - Z-Systems Opti-patch
Lexicon MPX-G2 Guitar Processor - .003r
Command 8 - Roland JV1000 + Triton Rack
FOCAL TWIN 3way speakers + JBL Q108MK11 Bottom
2-52 jax MilSpeck Patch Bays
2-22" Apple Cinema Display's
Allen & Heath 16ch Mixr
**Currently = 11-1-12
2 CD's Released-1-2003-2-2012 Worship ROCK
Old 04-04-2003, 06:06 PM
hello
yes i've downloaded it numerous times using IE as well.
Same result.
anything else?
thanks
Old 04-04-2003, 06:58 PM
Avid's Avatar
Avid Avid is offline
Administrator
I don't think that there is anyway that the download is corrupted if the installer launches at all. But just in case, I put an alternative download up of the same .dmg file further encoded as a .dmg.bin format file. The installers inside the disk image are identical, though.
I would look at using your OS X Disk Utility -> First Aid-> Repair Permissions as something to try before running the updater. You should always do that anyway after updating your OS, as stated on the bottom of this page:
http://www.digidesign.com/compato/osx/os.cfm
Also, remove or unmount any extra drives and peripherals, to reduce the places your updater is looking to just the startup drive, then run the updater.
Administrator
Old 04-04-2003, 07:43 PM
Hello again.
Ok this has been a frustrating day so far.
I ran disk utility repair first aid.
Everything checks out.
I downloaded the other version and I think your right about there being no corruption in the file since it does the same thing. Still hangs up on 134 items left to install. How long should installing an update take??
Surely not longer than a few minutes. Anyway same problem is happening.
Any other suggestions?
Thanks
frustration.
Old 04-04-2003, 09:00 PM
joeshepard joeshepard is offline
I'm having the exact same problem with the updater. It seems to be hanging at exactly the same place for all of us.
Joe
MacBook 16" Pro Max 2TB 64GB
Ventura 13.6
Pro Tools Ultimate 2023.12 (Native)
Logic Pro 10.7.9
Eucon 2023.12
2 Artist Mixes
Avid Control on an iPad
Soundflow & Streamdeck XL
UA Apollo|x|16, UA Apollo Twin|x, UA TB Octo Satellite
Old 04-04-2003, 11:29 PM
Anyone figure this out yet??
Old 04-05-2003, 03:56 AM
Jitter Jitter is offline
Try uninstalling the whole protools 6 and do a fresh reinstall
Old 04-05-2003, 04:22 AM
I suspect you are Maybe running an inferior/un-authorized computer?? ram?? HD ??
Tell us about your setup--.what you are Using... [img]images/icons/cool.gif[/img]
Isaiah 40:31
PTLE 10.3 LE
Old 04-05-2003, 01:24 PM
Unauthorized? no.
dp 800mghz 768mb ram
80gb drive with a super drive.
geforce card. Everything checks out.
The software I'm running is fine.
Nothing unauthorized.
Anything else?
Software Updater problem fsrenduro macOS 2 02-12-2014 08:24 AM
LE 8.0.5 updater problem (Pissed!) MichaelUR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-01-2011 11:06 AM
problem installing strike updater for mac os ranas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-05-2010 11:42 AM
Pro Tools Software Updater Problem? HermanV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2009 09:19 PM
Pro Tools 7.0 Plugin Updater Problem instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-19-2006 07:38 PM
