Old 10-17-2001, 09:00 PM
polyorchid polyorchid is offline
Default 800 min Bounce to disk for 4 min song?
This is the strangest thing I've seen yet. This is on a friends rig by the way.
When he bounces to disk, the bounce clock that counts down backwards reads 800+ minutes for a 3-4 minute song. The region is highlighted so the bounce should'nt go past that end point, but it does. A 60 second highlighted region is a 600+ minute countdown. The numbers are random.
This happened when he upgraded his 9600 to 9.1. I told him that he probably needs to reinstall his system and apps. Has anyone ever seen this?
polyorchid
Old 10-17-2001, 09:02 PM
Default Re: 800 min Bounce to disk for 4 min song?
After a low level of course...
polyorchid
Old 10-18-2001, 05:32 AM
JohnGalt JohnGalt is offline
Polyorchid,
Make sure the "Link timeline select
and edit select" button is enabled.
It's on the upper left of the Edit
window, to the right of the "a...z"
button and under the Grid button.
It's the one with the arrows pointing
up and down.
If this is not enabled, your bounce
will be the entire length of the
session, or the length of the timeline
select. [img]images/icons/smile.gif[/img]
When you once describe a venture as a holy war, you surrender all capacity to judge honest alternatives.
-James A. Michener
Old 10-18-2001, 07:49 AM
greg_lawrence10 greg_lawrence10 is offline
bush didn't write that quote either... he, like most pres., had someone write it for him....
Old 10-18-2001, 09:42 AM
Good call - thanks, I'll check that out.
RS
polyorchid
Old 10-18-2001, 09:57 AM
He ended up trashing the prefs and everything was cool. Thanks again.
RS
polyorchid
Old 10-18-2001, 10:02 AM
Sorry for the multiple posts.
I disengaged the link timeline/edit button on my rig to see if it would give the same result. At first I had a error-1309, but at the second attempt it bounced fine, I guess it was a prefs issue after all.
RS
polyorchid
End of song won't bounce to disk!!!! Mboxer2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-24-2007 04:54 PM
Song lenth triples when doing Bounce To Disk, WHY? Killah Kane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-21-2007 11:41 AM
Bounce to disk with song position markers? tj1507 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-03-2004 01:12 PM
HELP! - can't delete blank space at end of song b/f bounce to disk Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-26-2003 08:57 PM
14 min. bounce to disk for 4 min. song? waldo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-13-2001 07:43 AM
