Old 08-19-2006, 03:42 AM
xes xes is offline
Default Lame latancy problems
Im currently running PT m-powered 7.1 with my delta 1010lt soundcard and im having absolutly aweful latancy problems.I cannot set a record mode that works.When recording a track it sounds fine, but when played back its really out of time, the only way for me to get a tight recording is adjusting the buffer size but then its riddled with delay.....help !!!
Old 08-19-2006, 10:00 AM
spkguitar's Avatar
Default Re: Lame latancy problems
You should always track at the lowest buffer size your computer can acheive.
Old 08-20-2006, 08:12 AM
TNM TNM is offline
doesnt pro tools compensate for recorded audio on playback?
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X.
Old 08-24-2006, 10:51 PM
valayah valayah is offline
NO
Old 08-26-2006, 12:21 AM
Aedryan Methyus Aedryan Methyus is offline
Mute the track you're recording on and adjust the mix and volume levels on your MBox accordingly while you're recording.
Hopefully that will work for ya.
- Aedryan
help w/ Tape flange and latancy calculations w/ 003 LE OnTelephone Tips & Tricks 1 02-13-2009 07:58 AM
Auto input latancy compensation? James Drake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-18-2007 07:53 AM
Can u use click or metronome with low latancy on? idolizetravis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-14-2005 01:54 PM
low latancy in logic 7? staedtler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-17-2005 07:05 AM
HELP, Headphone latancy Marching Ant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-05-2001 09:21 AM
