Copy plugin settings apply to bypass state?
Hi
I feel like this works different every time i try it. If i command shift c to copy plugin settings to paste does that apply to a bypass state? Usual workflow is me copying eq settings of pro q and then highlighting an area further down the timeline (to extend my eq settings that i had further down the timeline), pasting it and then writing to selection. My eqs are never really bypassed so it doesnt come into play but when i do the same process with voice denoise (which i typically have bypassed) to again extend the processing, everything is pasted but its still bypassed if that makes sense. |
Re: Copy plugin settings apply to bypass state?
No bypass is not included in copying plugin settings. One of the mysteries of PT's development history.
~Will |
By the way, I don't work this way. For this, I use Automation Preview. Then I either go back to Clip1 and select Copy in the Plugin (to capture the settings I want) then go to Clip2 and paste, then "Write Automation to Selection" (usually with the button on my controller). Or, just go to Clip2 and pull up my Saved Preset Called "Clip1", then "Write Automation to Selection" (usually with the button on my controller). This always writes Bypass Automation if it is changed.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
EDIT: OK thinking about it maybe it does depend on automation? I know I've had to manually press bypass...
~Will |
what ive experienced is that when i command shift v (paste) the plugin settings i want to the new clip, it DOES change the bypass state to the state that it was in when i copied the plugin settings. Its after i write to selection and click from say clip 1 (where i copied the settings) to clip 2 (where i pasted settings) the bypass state isnt changed. IME its like something isnt happening during the 'write to selection' command not neccessarily in the copying and pasting of plugin settings if that makes sense.
AUTO-APPLY plugin automation settings to SIMILAR CLIPS ??!! | Benny Mouthon | Post - Surround - Video | 5 | 09-24-2024 10:52 AM |
Copy/paste plugin settings? | jmattchan | Avid S4/S6 | 31 | 06-16-2021 08:28 AM |
Copy Plugin Settings 12.8.1 Missing | TrentWilliams | Pro Tools 12 | 2 | 08-30-2017 06:17 PM |
PT10 TDM plugin settings copy broken when audiosuite open | Postman | Post - Surround - Video | 6 | 12-21-2011 07:31 AM |
Copy plugin settings suggestion | thierryd | ICON & C|24 | 8 | 08-11-2009 03:08 AM |
