Old 12-02-2013, 06:35 AM
A Chapman A Chapman is offline
Default Elastic Audio Properties not working - 10.3.7 / 11.0.2
Hi folks,
I'm running assessments for some students, and I've come up against a really weird problem in one of the rooms.
In this room, when they right-click in regions on an elastic audio-enabled track, and select Elastic Audio Properties, the window comes up as "No elastic audio enabled clips are selected". This is the same for all similar tracks, on both ticks and samples based settings.
It was the same in 10.3.7 and 11.0.2. I've manually trashed all the prefs (can't install the helper for 10). The room next door has the same session and it works fine. Anyone seen this happen? Any ideas for a fix?
Many thanks!
PS - setup is an iMac 27" i5, HD Native Thunderbolt, Omni IO. Same in the other rooms, but they are working fine, which is what's really odd about this problem.
Elastic Audio Properties Question Michaeldante 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-06-2010 09:07 PM
Elastic Properties lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-20-2009 06:20 PM
elastic audio properties for fender rhodes audioczar Pro Tools TDM Systems (Mac) 11 05-28-2009 02:00 PM
No Elastic properties in 7.4 xxicjoy Pro Tools TDM Systems (Mac) 2 02-27-2009 02:44 PM
Elastic Audio Properties | Weirdness 25ghosts Pro Tools TDM Systems (Mac) 11 04-08-2008 10:35 AM
