#21
Re: Is there a bug in the RB01 b green model ?
I've run some tests, I think I can confirm that the MIDI bug is legit as well. Guess nobody else is trying to control external gear via MIDI other than me :P |
#22
i'll see what I can do. Its happened at least 3 times to me, some times it doesn't happen.
#23
So im not the only one. I'll see if I can re-create it and screen grab it if I have time. It doesn't seem to happen every time, just once in awhile, which is why I have never brought it up before.
#24
But the biggest reason I am not surprised is because for clean sounds, you all out did yourselves with the DC Modern and Vintage Clean amps - amazing sounding amps.
#25
By they way I have confirmed that the DYN III compressor is also suffering from a bug. I will post a video. I havent had time to go through everything that may affect this, but can confirm the compressor does not actually work until you nudge the ratio, then it kicks in. In my other post i was thinking it was the Threshold knob, but its the Ratio knob.
I probably should have said something about this sooner. I made another thread for the DYN III bug. http://duc.avid.com/showthread.php?t=312333
#26
I was thinking it was the Threshold knob, but it was that the threshold has no effect until the ratio knob is nudged. I posted a new thread for it with a video included. http://duc.avid.com/showthread.php?t=312333
#27
I think I understand what's going on here...
This can be reproduced using only the ER front panel controls, BTW. It seems that when you load a patch with the RB-01b Grn amp (or come back from tuner mute), the Boost knob setting is honored. When you change the Bright switch, it's as-if the Boost gets goosed to 10. Try this: set Boost at 10 and see whether you get the same unexpected volume/grit increase when you change Bright. I don't. |
#28
I too have been noticing the bright switch bug on the XTC Green. I thought I was crazy until I ran across this thread, lol. So is this going to be addressed in a future release and if so, when? Thanks -Frank
Frank Silano FrankenCat Productions Landmine Recording Tampa Bay, Florida http://www.frankencat.com <>< PT 2018.12 (Win) PT 10.3.10 (Win) Mbox Pro Gen 3 Firmware 1.0.4 Focusrite 18i8 Gen 2 (mobile rig) Windows 10 Enterprise (main PT OS) Mac Mojave 10.14.4 (no PT at the moment) |
#29
I wouldn't get my hopes up. Look at the dates from the original posts, it seems pretty grim.
I would love to be wrong. |
How do you know if you have a Green, Blue or non Green or Blue Drive | [email protected] | Pro Tools 10 | 14 | 12-25-2013 12:13 AM |
M-2 model | derker | Eleven Rack | 6 | 05-23-2011 02:02 PM |
OT: What are Green Day doing? | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-11-2005 11:50 AM |
where is model # on G5? | Lega | Pro Tools TDM Systems (Mac) | 5 | 10-17-2004 07:05 PM |
MAC OS 9.1 or OS 9.2 on first model 733/DVD | mozart | Pro Tools TDM Systems (Mac) | 4 | 02-06-2002 01:44 AM |
