Old 10-11-2012, 04:40 AM
Christer-André Christer-André is offline
Default Automatically naming channel strips
Hi!
I have a mix template that I use.
Is there a way to name the channel strips automatically when dragging audio to the edit window?
When importing audio and selecting "new track", the names are automatically added to the track.
Is there a way to do this when dragging audio to a template?
Naming 50 + tracks takes quite some time :)
Thanks in advance.
Christer
Old 10-11-2012, 08:37 AM
robo6675 robo6675 is offline
Default
If you use the import audio command instead (shift+cmd+I) the track will be named the same as the audio file. Perhaps that will help save you some time.
MacBook Pro (silver) 2.5 GHz Intel Core 2 Duo - 4 GB RAM - 10.6.6 - PT9 - 003 BLA sig mod
Terrarium
HD3 Accel on a PowerPC - OS 10.5.7 - PTHD 8.0cs2
(3)192/SYNC IO/CS HEDD192/Studer A27/Neve 48 Ch. VR console
Old 11-02-2012, 02:54 AM
Default Re: Automatically naming channel strips
Thanks.
I could, but I have a template that I use with tracks that are organized and routed in a certain way.
When using the import audio command I have to re-organize the tracks, routing them, adding them to existing groups etc.
So what I wonder is if there's a way to import audio to the clip list, drag those tracks into my template and then name the channel strips automatically when dragging the audio to the edit window.
Any ideas?
Thanks.
Christer
Old 11-02-2012, 01:54 PM
I think I understand what you want, but don't think its possible. When using a template, the trick would be to create a larger template with enough tracks to cover your "worst case" mix(the most tracks) and name them in a way that works for you. Then, when you import your audio, bring it into the clips bin, then drag each audio clip to the track you want it on.
Old 11-02-2012, 03:28 PM
Tweakhead Tweakhead is offline
QuicKeys can be programmed to do just about any task including what you describe.
http://www.startly.com/products/quickeys/mac/4/
Channel Strips & Pro Tools 10 Becharax Pro Tools 10 21 10-18-2012 09:06 AM
Control 24 channel strips dickybabes ICON & C|24 0 02-07-2009 07:34 AM
Cant see channel strips in mix window hejira6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-29-2006 11:03 PM
Channel Strips WaDa TanK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-17-2005 09:19 AM
Question about channel strips Sennheiser Digidesign Hardware & Software 6 07-30-2002 09:23 PM
