Control tempo with MOD wheel
Allo,
Does anyone know if it's possible to control (and write automation for) the main session tempo using a midi MOD wheel. I have a piece of delicate piano music recorded and quantised in midi and now I want to vary the tempo in places to give it expression and nuance. I'd also like any tempo variations (like rallantando or rubato etc) to show in the score view. Any ideas if this is possible and how to do it apart from drawing the tempo changes manually (i'd like to be able to push and pull the tempo live). Thanks for any thoughts or info. Wayne |
Re: Control tempo with MOD wheel
To my knowledge the answer is unfortunately no.
Recently I engineered an electronic track where the Producer wanted it to slow down in the middle. It was one of those things where it needed to be felt and performed real time, but despite scouring the Protools reference manual and DUC, I found no way of achieving this. The tempo operations window does have some options for making tempo "curves" parabolic etc, which ended up helping in my situation, but at the end of the day, it was all contrived. A bit like drawing in piano parts on a midi editor. One thing I didn't explore was getting Protools to chase a hardware sequencer with a tempo knob. . . maybe it'd work. |
Thanks for that Allstaar,
Thats what I presumed. I think i'll be following the same route as you used and draw in the tempo changes as realistically as I can. I don't have an outboard sampler so I'll leave that for someone else to experiment with Cheers |
They both would be exciting if they worked!
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Using the wheel on Artist Control v2 | Trazan | Artist Series | 8 | 06-05-2012 11:41 PM |
Control Wheel response settings. | DigiTechSupt | Artist Series | 0 | 05-04-2011 01:54 PM |
Mackie control jog wheel | lordtom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-27-2010 05:34 AM |
Pro Control Scrub Wheel in 7.2 | iamnerdyrocker | Pro Tools TDM Systems (Mac) | 1 | 12-08-2006 11:02 AM |
Funtion of scrub wheel on pro control | Jules | Pro Tools TDM Systems (Mac) | 9 | 01-22-2000 07:21 PM |
