Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-03-2024, 04:13 AM
And#PT And#PT is offline
Default Using multiple interfaces in ProTools - even identical interfaces possible?
Hello, in the Mac's audio MIDI setup I can combine several audio interfaces into a new main device and then use this as a playback engine in ProTools. The inputs and outputs of these different interfaces are then available there. So I can connect a Steinberg and a Behringer interface together, etc. But what happens if I want to bundle two identical interfaces? I tried this with 2 Behringer UMC1820 that are currently being manufactured. This means you would have at least 36 inputs and 40 outputs available for just EUR 500. However, I couldn't get it to actually work. I can combine both UMC1820s into a new main device in the audio MIDI setup. If I then select this new main device in ProTools, all inputs and outputs are also correctly listed in the I/O setup in ProTools. I can also route the signals accordingly. But unfortunately there is noticeable noise on some channels, and the signal comes out much quieter on the second interface. All settings etc. are correct, I rule out an error on this page.
Is it possible that ProTools (or the Mac already in its audio MIDI setup) can't handle it when two identical, identical interfaces are addressed? The same drivers are used. Does this bundling or combining of several interfaces into a new main device actually only work if you use different interfaces?
(MacOS 10.15, PT 22.12)
Andi
Old 04-03-2024, 04:59 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Using multiple interfaces in ProTools - even identical interfaces possible?
Is the volume set the same on the devices individual pages in the audio midi setup?
I don't use aggregate devices, but I assume the individual setup affects the aggregate device as well.
Old 04-03-2024, 07:12 AM
Yes, all settings in the audio MIDI setup are identical.
Alternatively, I selected one of the two connected UMC1820 directly/separately in the ProTools peripherals (then only 18/20 I/O). The following happens there: only the first interface (top in the peripherals) always works, even if I select the second (bottom) one there. This means that a signal that is routed to Out1(1) of the second interface still comes out to Out1 of the first interface. I suspect that ProTools (or MacOS?) cannot distinguish between the two interfaces due to the identical name (and identical drivers). Is this assumption correct?
It is not possible (for me) to give the identical interfaces a different name, which might help.
Andi
Old 04-03-2024, 07:32 AM
devinemke's Avatar
devinemke devinemke is offline
Configure the 2nd device via the Pro Tools Aux I/O system.
You will need macOS >= Big Sur + Pro Tools >= 2022.9.
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 04-03-2024, 11:24 AM
Andi
macOS aggregate I/O is built into a low-level in CoreAudio, it will not have routing problems, and neither is Pro Tools likely to. CoreAudio and Pro Tools do not rely on the names you see to identify devices (which all internally have unique CoreAudio audio device object identifiers), these systems were not designed by total idiots, and aggregate I/O and Pro Tools will work with aggregates of identical devices (this is not unusual at all for some folks to do), ... within the standard caveats of using aggregation with Pro Tools.
And those standard caveats are... you should avoid aggregate I/O where possible, it can introduce timing and performance issues, aggregate I/O in Pro Tools was introduced to allow aggregating Mac built-in speaker/output to other interfaces, and Avid used to document that was the only supported configs, no idea what they say now. The quality/robustness of the aggregate device is largely dependent on the quality of the device driver. Vendors like Motu deliberately put effort into making sure their drivers work well in an aggregate device. RME drivers work well in aggregate because well RME driver quality.
You are trying to aggregate cheap Beringer interfaces that rely in low-performance USB class compliant drivers??... I would have low expectations that will work reliably/well (eg at low HW buffer sizes).
When aggregating interfaces like this you should have one box driving the clock into the other. Did you do that?
If you are having signal routing problems it is most likely something you are doing wrong, stop assuming the software is broken and focus on what you are doing, possibly how you are using the UMC mix control hardware mixing in each of these boxes... that knows nothing about the aggregate I/O and works as if the boxes are entirely separate and can easily lead to confusion with aggregate setups
And hopefully you are not trying to do this with Pro Tools Intro or Artist as you will just run into their IO limits.
Old 04-03-2024, 11:31 AM
I would hope there is no fundamental reason Aux IO works any better here than aggregate I/O and it may introduce latency/ADC issues. But it is a good idea and worth trying maybe just because it gives a different view of I/O and might help with any routing confusion.
The hardware mixer/mix control setups in both boxes should be excluded first as a possible factor.
Old 04-04-2024, 11:27 AM
EGS's Avatar
EGS EGS is offline
... But what happens if I want to bundle two identical interfaces? ...
Dunno about two 1820's, but you can daisy-chain two identical Presonus 2626 interfaces on Mac or Win:
https://support.presonus.com/hc/en-u...c4Ny42MC4wLjA.
Desktop build: PT 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626
Laptop: PT 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820
Click for audio/video demo
Click for resume
Old 04-04-2024, 01:55 PM
Nope. These are low-cost class compliant USB interfaces, heck they are USB 2.0 class compliant devices which pretty much guarantees low-performance. So not going to be great interfaces at low H/W buffer sizes, and really likely to be not great when aggregated. And being class-compliant USB they are not going to do anything fancy like chaining as supported by many *Thunderbolt* interfaces from UAD, Apogee, and Presonus.
What I forgot to mention before is the "proper" way of expanding these interfaces is to use ADAT. It's great that they have ADAT and great that they have a stand-alone mode to enable chaining an 1820 off ADAT on another 1820. (edit: correction--the 1820 does not seem to have a stand alone mode).
Old 04-05-2024, 08:56 AM
EGS's Avatar
EGS EGS is offline
Originally Posted by Darryl Ramm View Post
... It's great that they have ADAT and great that they have a stand-alone mode to enable chaining an 1820 off ADAT on another 1820.
As far as I can tell (I hope I'm wrong), the 1820 does NOT offer a stand-alone mode, i.e. it canNOT be used as an ADAT slave expander to another 1820.
Click for resume
Old 04-06-2024, 12:11 PM
I think you are right, I was going by some comments posted online by Berringer, cough, on Twitter/X. When you look at their (horrible brief) doc and other comments its clear they only talk about using their dedicated ADAT preamp product with this interface.
Multiple interfaces onto protools diego18br Pro Tools 11 6 09-12-2013 06:09 PM
Multiple interfaces Julia B Pro Tools M-Powered (Win) 3 06-22-2011 08:07 PM
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
Multiple Interfaces Larryboy Pro Tools 9 4 11-16-2010 08:11 AM
Multiple Interfaces in ProTools LE? rtcstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-22-2002 04:43 PM
