Old 02-01-2007, 05:56 PM
dts.music dts.music is offline
Default How to Get the \"Scratched Record\" effect?
Can I get it without using audio on a track or is that what triggers it? I want some record scratch/dust in parts of a song where there's silence. I have "Vinyl." Any ideas?
Old 02-01-2007, 06:12 PM
spkguitar's Avatar
Default Re: How to Get the \"Scratched Record\" effect?
Your question confuses me a little. Vinyl is a plugin. It does exactly what you're asking about. It can be used to effect any audio passing through any track that it is inserted on; the audio does not need to be recorded to the track to be processed.
What is it exactly that you are trying to do?
Old 02-01-2007, 07:54 PM
VanAmp VanAmp is offline
I have never used vinyl but I would try this.
Add and aux track add vinyl to the aux track and in the edit window draw in volume automation to add the effect to desired locations.
try it and let me know how it goes
Old 02-01-2007, 09:24 PM
scratch/dust by itself, like an old dirty record before the song starts...
Old 02-02-2007, 08:21 AM
funeral funeral is offline
you can buy samples of audio with 'scratches' / noise on them - otherwise some synths produce that type of sound, my korg tr does...........
you could use the plugins mentioned above but these only work when audio is passing through...................
ever thought of buying an old record player and making the sample yourself?
Old 02-02-2007, 08:54 AM
Mr.BossPlaya Mr.BossPlaya is offline
sample tank 2 has that effect you're looking for
Old 02-02-2007, 09:12 AM
wheresmyfroggy wheresmyfroggy is offline
http://sounddogs.com/
Should find some here
Tom
Old 02-02-2007, 10:02 AM
spkguitar's Avatar
That's actually not true. The vinyl plugin, when inserted on an AUX track will produce this effect; no audio has to be passing through it at all. To record the output of the plugin to an audio track, you would just bus the output from the aux track to a record enabled audio track.
Old 02-03-2007, 09:46 AM
Majorek Majorek is offline
I get and simulate the effecst of old vinyls with the great izotpe Vinyl plugin.
That's definitly what you should give a try, here: http://www.izotope.com/products/audio/vinyl/
Have fun scratching and putting dust into your sounds!!
MacBook Pro - OS X 10.6 - Pro Tools LE 8 - Mbox 2
Drone / Ambient / Experimental
Can I record with insert effect? cuttothebeat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 06-15-2017 10:38 AM
Looking for Record Player turning on effect... nexis General Discussion 13 01-06-2013 06:07 PM
Record/Tape Switch Off Effect The Dougfather Tips & Tricks 4 06-10-2007 01:53 PM
slow down record effect Locash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 03-06-2004 01:32 AM
Record Stop Effect snoopy Tips & Tricks 7 11-01-2002 05:02 PM
