Old 06-22-2017, 08:45 AM
jjsoundoc jjsoundoc is offline
Default Has anyone tried NVIDIA 10 series card?
I've been experiencing the jerky behavior in timeline with new 12HD/Native/Artist Mix combo. Talked to "support" who thought the problem would be fixed with 12.8 Or, it could be helped with a newer video card.
Nvidia has released a new mac compatible driver that should allow me to use a GTX 4gb 1050 with the drawback of not having a boot screen.
Has anyone tried a 10 series nvidia video card?
JJ
MP '09 quad 2.66, Yosemite, GT120 Graphics card, 32gb Ram, SSD main drive, Native card, 12.7 PTHD, Omni, Artist Mix
Old 06-22-2017, 10:08 PM
arche3's Avatar
arche3 arche3 is offline
Default Re: Has anyone tried NVIDIA 10 series card?
I got a Radeon r9 280x. Flashed with boot screen. Fixed my graphic and 9073 cpu issues.
Look at this on eBay http://www.ebay.com/itm/271581797329
Sent from my SM-G955U using Tapatalk
Old 06-27-2017, 07:07 AM
DetroitT's Avatar
DetroitT DetroitT is offline
GTX 1080 8GB (Best power choice) MacVideoCards flashed (A bit pricy but done right).
4K primary but in Pro Tools I run 1440P (AOC 30") (too fine for computing but in film it looks great.
BTW HD12.8 did improve multi monitors (Displays) with this card.
Changed from Radeon 7950 Mac edition..
Almost no errors in Sierra it is a bit noisier 8 pin power draws from both Mac PCIe sources.
(I have the same splice for the HDX card so install was seamless.
Old 06-28-2017, 09:40 PM
lucienpalmer lucienpalmer is offline
I have a GTX 1070 from macvidcards.com.
So far so good.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M10 16-5, Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 07-06-2017, 01:08 PM
lancemcv lancemcv is offline
FYI if you are interested in AMD cards Apples next update 10.12.8 will support the newest cards like the RX 580s which is great news if you also do video editing in FCPX like I do, you can run them now but you have to do a kext edit to get them working. But the next OS update you won't have to as it will have native driver support. Could be a good sign for the next mac pro in 2018 as Apple seems to be sticking with AMD.
I have a flashed 980ti and its working great with pro tools just have to update the driver every time you update the OS but they have been good about getting Apple drivers out lately. You can pick those up on eBay pretty cheap compared to a year ago but the 980ti needs two power feeds but it is not as fast as AMD cards with FCPX. The new 1080 and 1070 only need one power feed. 1080ti needs two and can still draw too much power when stressed.
My 980ti and 12 core 3.33 mac pro has never had an over heat related shutdown I would only switch to AMD once 10.12.5 come out as I am starting to do a lot more editing and would not mind the speed bump. Could install two of those babies possibly.
Pro Tools Ultimate 2021
opencore 0.6.9
Mac OS Big Sur 11.2.3
Mac Pro 2009 upgraded to 5,1 12 core 3.33ghz
GPU RX5700XT, Samsung SM951 M.2 PCIe SSD (AHCI model) pcie boot drive, Sonnet usb 3.1 card
Midas M32r console. iPad Pro with Avid Control
Old 07-06-2017, 03:59 PM
DetroitT's Avatar
Thx for the share.
(AMD)
Old 08-25-2017, 11:40 PM
iBuildMacs iBuildMacs is offline
Yes, with PT 12, you should get rid of that GT120 graphics card. You don't need anything super high end. Even a ATI 5770 1GB should solve the issue. If you want to play it safe, go for a GTX 680.
Waves SSL plugs and nvidia gfx card Haggis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-09-2006 02:32 PM
setting up nvidia card? agus Pro Tools TDM Systems (Mac) 4 11-06-2003 11:57 AM
New Dual AGP NVIDIA video card? thermal Pro Tools TDM Systems (Mac) 8 04-01-2002 10:57 AM
NVIDIA Geforce 4 card guitates 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-28-2002 07:35 AM
Nvidia Chipset and AMIII Audio Card RandyLLLL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2001 05:56 PM
