Old 07-05-2014, 10:31 AM
MTStudios_Skitch MTStudios_Skitch is offline
Default Midi input stopped working. Works fine outside of Pro Tools
I'm working on a session created in Pro Tools 10. I've recorded a mixture of Audio/Midi/Instrument tracks a few weeks ago in a session. I pull up the session, create a new instrument/midi track, and when I play on my keyboard it's as if nothing is happening. Nothing in my setup has changed, and outside of pro tools stand alone applications such as Addictive Drums or Kontakt 5 are able to accept midi just fine.
I've made sure that the "midi thru" is checked, and in my default midi thru device is "none" (When I change it to output through my audio interface midi, it sends the midi just fine but I still can't record at all). So obviously the cable and the midi are working, just not in this session. If I open up older sessions the midi works, so it's got to be a setting or something that somehow changed even though I haven't done anything. Thoughts?
Pro Tools 10
Windows 7 64-Bit
M-Audio Fast Track Ultra 8R
Yamaha KX88 Midi Keyboard
Thanks guys, any help would be greatly appreciated. I've been searching for hours and can't find any posts or anything that have been able to solve my problems.
Old 07-05-2014, 10:52 AM
Southsidemusic's Avatar
Default Re: Midi input stopped working. Works fine outside of Pro Tools
Hi and Welcome to the Community
You are sure you have checked the settings in midi device area where your midi keyboard needs to be checked in the box? and that you have the record enabled button on the track you are trying to get sound from!?
Best Regards
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-05-2014, 11:36 AM
Best Regards
Christopher
I assume when you say midi device area, you are talking about the "Midi Input Devices" section under setup? If so, then yes both of my midi input interfaces are checked there.
As far as having record "Enabled" on the tracks i'm trying to send, is this a new feature? I used to just be able to select the track I was working on so it would highlight itself, and then stream the sound without having to record enable it. Is that not possible anymore?
Old 07-05-2014, 01:48 PM
Midi input device was what I meant as you pointed out.
Regarding the rec enabling I don't know for sure but we always need to enable the track we are using so I assume you did that already.
I am going into the studio later on tonight and will look at your post again. Maybe someone else will know by then otherwise I will post back.
Best
Chris
Best Regards
Christopher
#thestruggleisreal
WEBHOME
built in output on mac stopped working-works fine in 10 mortenbrekke Pro Tools 11 1 07-09-2013 01:48 PM
MBox3 Channel 01 has stopped working. Ch#2 is fine? Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2011 09:21 PM
Midi input stopped working on Mbox 2 Pro mrshonuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-07-2009 09:28 PM
Why has midi input stopped working except with Midi Thru enabled? Martin Dubka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-11-2008 07:43 AM
AudioSuite stopped working, RTAS fine=??? curve666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-08-2001 07:22 AM
