MIDI I/O not showing up in Audio Midi Setup
I've got a TDM system, running PT 6.9.2 on an Apple G5 (OSX 10.4.3) and can't get my MIDI I/O to show up in the Audio MIDI Setup Utility. Does anyone have any suggestions? I have downloaded the latest drivers and everything, but for some reason its just not showing up. Please advise......
Re: MIDI I/O not showing up in Audio Midi Setup
Try plugging it into the USB 1.1 port that's on your keyboard. Or try another USB port. Try using a powered USB 1.1 hub.
I had to jump through a few hoops to make my midi i/o work with the G5... it now works perfectly, but it's on a powered hub that's on the keyboard's USB port. Go figure.
--Jeremy |
Hi.
Answerbase: http://answerbase.digidesign.com/detail.cfm?DID=30000 http://answerbase.digidesign.com/detail.cfm?DID=29864
midi firmware updater in the pro tools folder
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Multiple MBox Pro Instances/Icons in Audio MIDI Setup -> MIDI Studio | lpeckham | macOS | 8 | 04-24-2014 06:39 AM |
MTP AV not showing up in my Audio Midi Setup | siuberto Socarras | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-17-2013 08:56 AM |
Midi Devices not showing up after setting up Audio Midi Setu | nick535nak | Pro Tools TDM Systems (Mac) | 4 | 09-23-2007 01:15 AM |
PT7 *midi time piece not showing up in midi setup | pigmeat | Pro Tools TDM Systems (Mac) | 1 | 12-20-2005 08:12 AM |
002 Not showing up in midi setup. Please help | toddm7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-17-2005 03:39 PM |
