Multiple HD I/O question
Hello all
I have a C24, paired with an HD I/O and HDX PCI Card, running Protools 11. This is my original setup. I like to purchase an additional HD I/O (all analog) in order to ADD CHANNELS coming in/out capabilities. Question might be dumb, but I've been told there is not such thing as a dumb question... Will my SECOND HD IO interface be recognized by protools 11 and allow me to use the extra ins/outs? That's it.. Thanks for the help!!! Cheers David |
Re: Multiple HD I/O question
It should just show up in Hardware(under the Setup menu). Don't forget to connect Loop Sync according to the manual. A single HDX(or HDN) card should handle up to 4 interfaces, for a total of 64 IO. I run an HD IO and a 192 on my HDN setup and have 32 working IO
BTW, assuming you currently feed the 16 preamps of the C24 to your first HD IO, you will need more preamps for the second(or any additional) IO's that you connect.
And yes, I'm aware I need pre-amps in front of the second interface. I was thinking to use the second interface for LINE IN type of stuff (where no pres are needed) or (on some channels) utilize my Avalon's Pre-Amp for vocals, etc.. - and the the first 16 I can use the C24 built-in pre's for tracking drums, guitars, etc. Again, THANK YOU!!! THANK YOU!!! I appreciate it sincerely, David |
Does it make a difference whether I connect the second interface in a "daisy chain fashion" instead of connecting it directly to my HDX card? What's the difference? I know it can be done either way.. but, are there advantages or disadvantages in either approach??
Whichever you choose, you will need to loop sync the boxes just the same way.
Multiple hardrive question | helpmeout5555 | Windows | 6 | 01-13-2013 03:37 PM |
Multiple Mac question..... | hemloc | Pro Tools TDM Systems (Mac) | 9 | 04-08-2010 08:38 AM |
Question about multiple TV monitors | johnnyv | Post - Surround - Video | 11 | 09-30-2008 04:26 AM |
Multiple 002 Question.... | tenoctaves | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-10-2004 03:21 AM |
Multiple 888/24 setup question | Chris Coleman | Pro Tools TDM Systems (Mac) | 2 | 06-24-2003 08:01 PM |
