Premier OMF Audio Distorted
Anyone noticing OMF's from Premiere 11.1.2 is putting out distorted audio? I have 3 projects from 2 different studios that have had that problem in the last 2 weeks. It is obvious on the 2 pop, which sounds squared waved.
Michael McDonough, M.P.S.E. Michael McDonough Sound Design Last edited by subwoof; 10-13-2017 at 11:44 AM. |
Re: Premier OMF Audio Distorted
Yes. I've noticed this as well, have not been able to trace where the issue arises though.
Thank you! I was starting to wonder if anyone else had noticed this. Maybe someone from Adobe will respond.
Michael McDonough, M.P.S.E. Michael McDonough Sound Design |
I'm an occasional lurker - picture editor with access to PP2017.1.2 and 2018.0.something - happy to do any tests for you.
I do think that the PP OMF burns in any levels changed - and there's multiple places to adjust gain in PP. I've made a test sequence of test tones and exported an OMF and AAF, with embedded audio. File is here Track layout is: A1 - mono, A2 - standard, A3 - adaptive ('standard' is default for PP) Clip layout is track ident then sweep (about -6dB) Gain layout is 00.00 - Unity 01.15 - Clip Gain +6dB 02.30 - Clip Mixer Gain +6dB 03.45 - Track Mixer Gain + 6dB (keyframed) OMF is 16 bit (default, there is an option for 24 bit) PP message is: Make sure your Pro Tools settings match the export settings. Check below for error messages Start Time is: 00:00:00:00 ProTools Offset value is: 0:0.000 Frame Rate is: 25.00 fps You can set this in Track Offset Options in Pro Tools. AAF is not 'split to mono' (default, there is an option). PP message is: The AAF file "/Users/rmbp_july2017/Desktop/DUC Exports/PP2017.1.2 AAF non mono EXPORT.aaf" could not be exported completely and/or accurately, as logged below: Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 1" (#1594086), Position: 3696, Time: 00:02:27:21) because it is not supported. Effect was ignored. Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 1" (#1594086), Position: 3696, Time: 00:02:27:21) because it is not supported. Effect was ignored. Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 2" (#1594086), Position: 3771, Time: 00:02:30:21) because it is not supported. Effect was ignored. Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 2" (#1594086), Position: 3771, Time: 00:02:30:21) because it is not supported. Effect was ignored. Cannot export audio effect "Internal Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 3" (#1594086), Position: 3840, Time: 00:02:33:15) because it is not supported. Effect was ignored. Cannot export audio effect "Internal Channel Volume Stereo" (Sequence: "Mono Standard Adaptive Tracks - Unity - Clip Gain - Clip Mixer Gain - Track Mixer Gain", Audio Track: "Audio 3" (#1594086), Position: 3840, Time: 00:02:33:15) because it is not supported. Effect was ignored. Hope that may be of some help in your diagnosis |
Distorted Audio in 10.1.1 | Rubicon | Pro Tools TDM Systems (Mac) | 10 | 04-11-2012 10:53 AM |
Premier on PC->PT on Mac Audio issues | Ken P | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-25-2005 10:21 AM |
Distorted audio from OMF | berk | Post - Surround - Video | 3 | 05-14-2005 09:18 AM |
Distorted audio from Headphone amp! | Tedmod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-09-2004 03:25 PM |
distorted audio | Ricco | Pro Tools TDM Systems (Mac) | 2 | 08-15-2000 03:26 AM |
