#731
Re: Problems with PTLE? Post your configuration here..
Purchased & installed 7.0... Also downloaded SP2 (I never thought it was stable) The 7.0 program is freezing at "Creating DAE.." (Not Reponding) in Task manager. I managed to launch & run the applicaion maybe twice at first.... other than that I have not been able to successfully launch 7.0 for 2 1/2 days. I have tried the recent updates 7.1 & 7.1cs to no avail. BTW - I have been successfully running 6 - 6.9 for 2 years with NO problems with the same config w/ the exception of a new 250GB SATA drive named Record2 (K:) Recording (D:) was always my drive for song files. Also, I did not delete digidesign dbs & DAE prefs in each drive for fear I was going to lose songs on drives. I actually ran the program with HTT enabled but disabled it when the program began to freeze (I actually bought 7.0 to utilize my HTT) I was beter off w/ 6.9 & SP1 A bit after I loaded 7.0 Windows media upgraded to 10.0 I was curious if that may have screwd things up?!? Please help.
Here's the skinny: Processor > Model: Intel(R) Pentium(R) 4 CPU 3.40GHz Speed: 3.40GHz Performance Rating: PR3740 (estimated) Cores per Processor: 1 Unit(s) Threads per Core: 1 Unit(s) Internal Data Cache: 16kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache: 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector < Mainboard > Bus(es): X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus MP Support: No MP APIC: Yes System BIOS: Intel Corp. SE91510J.15A.1022.2004.0726.1125 System: Gateway 700GR Mainboard: Intel Corporation D915GSE Total Memory: 2GB DDR-SDRAM < Chipset 1 > Model: Gateway 2000 82915G/GV/GL/P/PL/GL Grantsdale Host Bridge/DRAM Controller Front Side Bus Speed: 4x 200MHz (800MHz data rate) Total Memory: 2GB DDR-SDRAM Memory Bus Speed: 2x 200MHz (400MHz data rate) < Video System > Monitor/Panel: Plug and Play Monitor Adapter: RADEON X300 Series Adapter: RADEON X300 Series Secondary < Physical Storage Devices > Hard Disk: Maxtor 6Y160M0 (153GB) Hard Disk: WDC WD2500JD-00HBB0 (233GB) Hard Disk: WDC WD2500KS-00MJB0 (233GB) Hard Disk: eM Bay Reader USB Device Hard Disk: eM Bay Reader USB Device Hard Disk: eM Bay Reader USB Device Hard Disk: eM Bay Reader USB Device CD-ROM/DVD: SAMSUNG CD-ROM SC-148A (CD 48X Rd) CD-ROM/DVD: _NEC DVD_RW ND-2510A (CD 40X Rd, 32X Wr) (DVD 5X Rd, 4X Wr) < Logical Storage Devices > Hard Disk (C:): 233GB (199GB, 86% Free Space) (NTFS) Record2 (K:): 233GB (233GB, 100% Free Space) (NTFS) Recording (D:): 153GB (149GB, 98% Free Space) (NTFS) CD-ROM/DVD (E:): N/A CD-ROM/DVD (F:): N/A Removable Drive (G:): N/A Removable Drive (H:): N/A Removable Drive (I:): N/A Removable Drive (J:): N/A < Peripherals > Serial/Parallel Port(s): 2 COM / 1 LPT USB Controller/Hub: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 USB Controller/Hub: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 USB Controller/Hub: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A USB Controller/Hub: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B USB Controller/Hub: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Mass Storage Device USB Controller/Hub: USB Composite Device FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller FireWire/1394 Controller/Hub: OHCI Compliant IEEE 1394 Host Controller Keyboard: SENS Keyboard V6 Mouse: Microsoft PS/2 Mouse < Communication Device(s) > Device: PCI SoftV92 Data Fax Modem with SmartCP < Power Management > AC Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) < Network Services > Adapter: Marvell Yukon 88E8050 PCI-E ASF Gigabit Ethernet Controller < Performance Tips > Notice 5901: CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902: DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. |
#732
Lesbrunn,
best boot from a WXP cdrom and install your OS from scratch. Followed by the cdrom that you may have received from your motherboard, the patches that make your OS recognize your mobo + hardware. No Ghost boot cd's is my credo, for what it's worth. Plain WXP w/SPI should be fine if you're running DIGI 001 + PTLE 6.1. Good luck, Walther.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
#733
Hi, I am running ProTools 6.9 on a new computer, with a Digi002 (rack version). I keep getting the error message saying to 'Increase/decrease the H/W buffer size', no matter what size I've selected. This happens constantly, but only during playback (I can record with no problems). PT's often crashes after this message comes up. Also, less frequntly I get the 'DAE error occurred' message. Sometimes the controls go funny as well (the mouse scroll wheel zooms in and out instead of scrolling up/down. When I hit play it says 'waiting for sync', and I can't select grabber/magnifying glass). The only other program I run is AKSYS for my akai sampler. Here's my system info: Processor Model : AMD Athlon(tm) 64 Processor 3000+ Speed : 1.81GHz Model Number : 3000 (estimated) Performance Rating : PR2712 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB ECC Synchronous, Write-Back, 16-way set, 64 byte line size Mainboard Bus(es) : ISA PCI PCIe USB FireWire/1394 MP Support : 1 Processor(s) MP APIC : No System BIOS : American Megatrends Inc. 8.12 System : System manufacturer System Product Name Mainboard : ASUSTeK Computer INC. A8N-VM CSM Total Memory : 1.9GB DDR-SDRAM Chipset 1 Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration Front Side Bus Speed : 2x 1005MHz (2010MHz data rate) Total Memory : 2GB DDR-SDRAM Memory Bus Speed : 2x 200MHz (400MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 6150 Physical Storage Devices Removable Drive : Floppy disk drive Hard Disk : ST3250823AS (233GB) Hard Disk : ST380011A (75GB) Hard Disk : Lexar JumpDrive USB Device CD-ROM/DVD : HL-DT-ST DVDRAM GSA-4167B (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr) Logical Storage Devices Hard Disk (C:) : 75GB (69GB, 93% Free Space) (NTFS) Data (F:) : 233GB (187GB, 80% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A 3.5" 1.44MB (A:) : N/A Removable Drive (E:) : 246MB (235MB, 96% Free Space) (FAT) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Standard OpenHCD USB Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Microsoft PS/2 Port Mouse (IntelliPoint) Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Network Drivers Enabled : No Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#734
[QUOTE]
You don't use ghost installations from previous systems on your new A8N-system do you? Meaning a backup from an operating system (plus appz) that you made before. That'd be a no-go but I may be misunderstanding your question. Hello voideco, Yes, I did try that at the beginning. The solution was to load the images and then repair XP. Windows asks you for needed drivers, and fixes everything for the board to recognize your old installation. However, I scrapped that after using it for about a month, and did a fresh installation of XP and SP1. The board still would'nt read certain boot packages, notably Ghost and Partition Magic. My main problem was to back up my new installation, but I've been able to do that now by making a Nero boot CD containing the Ghost files. I can only access them with DOS commands,though. My other problem still stands unsolved: I can't use PT with any drive connected to the Promise. I still get "PCI bus too busy..." Does'nt the A8NE fully support Promise IDE controllers, or could the problem be from PT6.1's inability to cope with dual cores? (I assign it to one processor, yet get sudden system shutdowns when I open bombfactory plugins.) To make bombfactory work, I have to reassign PT to both processors, open the plugins and then go back to one processor! lesbrunn
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#735
Digi ETS,
Does PTLE 6.1 have a limitation on the number of plugins one can use? I've noticed that (for mono tracks) when the plugin list exceeds 256 items, everything scrolls back to the beginning of the list. In other words, clicking on the 257th item opens the 1st plugin on the list! This had me totally baffled for a week before I realised exactly what was happening. I had to remove less important ones. It does'nt happen with my stereo tracks because there are much fewer entries in that list. lesbrunn
#736
#737
I tried finding some info out in another post, but finally broke down and installed Sandra.
Dell Inspiron 9400 Laptop... brand new install of Protools 7.0 on xp pro sp2. All tips have been followed, all troubleshooting has been done. There are only 14 running processes running, so it is a very clean install with almost everything disabled. The Dual Core Fix made this machine a total nightmare, as did 7.1. (Did a fresh install of XP Pro SP2, downloaded all updates from microsoft, and streamlined again to get rid of it) I managed to get through davecII test 8 completely, but I cannot play any of my old sessions, even the small ones. (nothing happens when i hit play except for the cursor moving back a few frames) I get dae error -6087, audio drive is a brand new Maxtor 250 gb 16mb cache in an Oxford 911 Firewire enclosure. Quite often PT will not boot up on my first try. The computer starts it, hour glass moving, but all loading stops before any screens appear. Open the task manager, and protools is running, stuck at about 29000k ish, processor at 50% usage. Kill the process, and start protools again, and it will boot up fine. It just won't play any audio! Anyway, I bought this laptop to get a bunch of work done, and so far I have been getting no sleep for 5 days trying to make it work. I can slap together a desktop machine in a couple hours, running PT flawlessly... have built several for other people over the years... but this thing is killing me! Please help!!!!! Processor Model : Genuine Intel(R) CPU T2500 @ 2.00GHz Speed : 2.00GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : No System BIOS : AT/AT COMPATIBLE DELL - 27d60311 Mainboard : Dell Inc. 0YD479 Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Dell Computer Corp Mobile Memory Controller Hub Front Side Bus Speed : 4x 166MHz (664MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 4x 166MHz (664MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Adapter : ATI Mobility Radeon X1400 Physical Storage Devices Hard Disk : FUJITSU MHV2100BH (92GB) Hard Disk : Macpower OXFORD IDE Device 1 IEEE 1394 SBP2 Device CD-ROM/DVD : SONY DVD+-RW DW-Q58A (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 46GB (36GB, 79% Free Space) (NTFS) New Volume (G:) : 46GB (45GB, 99% Free Space) (NTFS) Audio (E:) : 234GB (160GB, 69% Free Space) (NTFS) CD-ROM/DVD (D:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : Generic USB Hub FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Synaptics PS/2 Port Pointing Device Communication Device(s) Device : Conexant HDA D110 MDC V.92 Modem Power Management AC Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Broadcom 440x 10/100 Integrated Controller Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
#738
DAE error - 1115
Hi. I just bought a new Dell Inspiron 6400 laptop and have been struggling to get Protools 7.0 and my digi 002 working on it, but every time I try to open Protools I get the message "DAE error - 1115" and it shuts. I've been talking to support all week and tried the following things which haven't helped - updating PACE, turning things like multicore off in the bios, re-installing protools etc. Any other ideas?
SiSoftware Sandra System Host Name : LAPTOP User : Brendan Workgroup : MSHOME Processor Model : Genuine Intel(R) CPU T2600 @ 2.16GHz Speed : 2.16GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : ISA X-Bus PCI PCIe USB FireWire/1394 i2c/SMBus MP Support : No MP APIC : No System BIOS : AT/AT COMPATIBLE DELL - 27d60414 Mainboard : Dell Inc. 0KD882 Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Dell Computer Corp Mobile Memory Controller Hub Front Side Bus Speed : 4x 166MHz (664MHz data rate) Total Memory : 2GB DDR2-SDRAM Shared Memory : 8MB Memory Bus Speed : 4x 166MHz (664MHz data rate) Video System Monitor/Panel : Plug and Play Monitor Monitor/Panel : Plug and Play Monitor Monitor/Panel : Plug and Play Monitor Adapter : Mobile Intel(R) 945GM Express Chipset Family Adapter : Mobile Intel(R) 945GM Express Chipset Family Physical Storage Devices Hard Disk : ST910021AS (92GB) Hard Disk : OTi Flash Disk USB Device CD-ROM/DVD : _NEC DVD+-RW ND-6650A (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 29GB (24GB, 81% Free Space) (NTFS) DATA (E:) : 62GB (62GB, 100% Free Space) (NTFS) Sound Bank (D:) : 699MB (CDFS) Removable Drive (F:) : 249MB (185MB, 75% Free Space) (FAT32) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse Mouse : HID-compliant mouse Human Interface : USB Human Interface Device Communication Device(s) Device : Conexant HDA D110 MDC V.92 Modem Power Management AC Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows XP/2002 Home 5.01.2600 (Service Pack 2) Network Services Adapter : Broadcom 440x 10/100 Integrated Controller Adapter : Intel(R) PRO/Wireless 3945ABG Network Connection |
#739
Update... I switched my firewire 911/USB 2.0 drive over to USB, and seems to have solved my problem. As a matter of fact, so did just playing the sessions from my system drive... no problem playing back 32 tracks of audio lol go figure.
Anyone know if there is a problem with the combo oxford 911/USB enclosures? Should I buy a firewire only enclosure? |
#740
Problems with PTLE? Post your configuration here...... | still_life_ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-30-2007 12:27 AM |
Problems with PTLE? Post your configuration here.. | DJ John | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-28-2007 10:06 AM |
Problems with PTLE? Post your configuration he | krsongs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-28-2007 09:59 AM |
Problems with PTLE? Post your configuration here.. | p3tch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-28-2007 09:46 AM |
Problems with PTLE? Post your configuration here.. | Gaba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-23-2007 08:01 AM |
