Old 07-02-2021, 10:03 AM
tsugi tsugi is offline
Default Floating Faders appearing suddenly!
Hi All,
This is a new one to me - I've just opened an exported session from an editor - when I select a track, a floating fader appears.
If I select via the desk, no faders.
Using the mouse - if I select the track name, or click on the track in the timeline - fader appears. This is all tracks - new ones too.
I know about the mini fader icons - all good, but this is annoying.
I've been through preferences, view, etc and I can't find anything that makes this happen. All the more frustrating because - as ever - I've changed nothing!
I n ow it's me, and that I've missed something obvious, but could one of you wise ones point me in the right direction please?
David
It's 2021.6
Cheers,
tsugi
Old 07-02-2021, 10:18 AM
Default Re: Floating Faders appearing suddenly!
Don't suppose you've got a Eucon control surface attached to this rig? If so it's in Eucon preferences.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 07-02-2021, 10:25 AM
I do! I've S3 Dock & Control - but I can't see the floating fader in the preferences or General. I'll keep digging. Thanks!
Cheers,
tsugi
Old 07-02-2021, 10:29 AM
And it only happens when I select via mouse (the output tab highlights as well, if that's a clue?)
If I select via the dock or Control - no floating faders
Hmmmm
Cheers,
tsugi
Old 07-02-2021, 11:11 AM
BScout BScout is offline
The floating faders pop up because of pan (which is the setting you are looking for in Eucontrol) since pan is on the same window.
"Open windows on workstation when editing"
make sure that drop down option isn't one that includes pan.
Old 07-02-2021, 11:28 AM
jeffro's Avatar
jeffro jeffro is offline
Set Open windows on workstation when knobs assigned from DAW click: in EuControl Settings > General to Off.
linkedin
Old 07-03-2021, 02:15 AM
I salute your brilliance, folks.
That did the trick. Thank you very much.
Now I've got to figure out why PT doesn't recognise the EUControl surfaces unless I restart EuControl! I suspect a bug from the latest update.
Cheers,
tsugi
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Error (-9073) suddenly started appearing... Ppblais macOS 3 09-14-2015 11:58 AM
Artist Mix: Faders 3 & 4 suddenly acting odd... Suges Artist Series 10 07-13-2013 12:27 PM
Floating Send Faders kidbazooka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2008 08:14 AM
Suddenly faders not moving...... Armando ICON & C|24 5 03-10-2003 09:38 PM
