Old 05-21-2021, 09:08 AM
karlossus karlossus is offline
Default M1 Logic Pro X & EuControl
I'd like to use my Avid Artist Mix with Logic Pro X on my M1 Mac mini. I can't at the moment as EuControl only runs under Rosetta and Logic Pro X only runs natively.
Does anyone know when or if an update for EuControl to run natively on M1 may come about? Or does anyone know any workarounds I've missed?
Thanks
Old 05-22-2021, 02:24 AM
dominicperry dominicperry is offline
Default Re: M1 Logic Pro X & EuControl
You can choose to run Logic Pro under Rosetta too, even if it's just for testing. (I'm not clear why running one app native and the other not would prevent the Artist Mix from working, but you may be right).
Just select the Logic icon (when Logic is not running) and do Command - I (Get Info). You can opt to run Logic under Rosetta.
https://www.macworld.com/article/338...p-instead.html
Dominic
Old 05-23-2021, 01:12 AM
Thank you Dominic.
I tried this a while ago and Logic crashed but tried again today and it does indeed work!
FWIW unless both DAW and eucontrol are running under rosetta the DAW doesn't see eucontrol so the surface doesn't work.
I'm really grateful to have a workaround but still hope to see M1 compatibility for EuControl soon.
Old 05-23-2021, 01:43 AM
JFreak's Avatar
JFreak JFreak is offline
Hi, welcome to the community.
Avid will tell their roadmap once they release something, nobody knows before. Sorry about that. Big Sur is already supported with latest release so it is only logical that Apple Silicon is work in progress.
Janne
Old 05-23-2021, 03:14 AM
Originally Posted by karlossus View Post
Thank you Dominic.
I now remember that there is possibly a problem with native and non-native plugins in Logic, depending on whether the plugins themselves are native or not. 10.6.2 is better than earlier versions. Anyway, be warned that you may have some plugin problems you didn't have before. Depends how important the EuControl is !
S1 EUControl - Need help!! jonpaulr123 Avid S1, S3, Dock and Control 1 08-01-2020 10:57 AM
EuControl v3.6 Now Available EddieJones Avid S1, S3, Dock and Control 7 06-01-2017 07:20 AM
Does S6 install Eucon/Eucontrol ? Logic crashes... vudoo Avid S6 5 05-03-2016 10:46 AM
EuControl is now a piece of crap with Logic 10.1 robertg Artist Series 28 02-28-2015 05:07 PM
EuControl crashing Logic Pro 9 on startup T S Artist Series 1 07-12-2012 12:52 AM
