Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-04-2006, 09:30 PM
ModaRecords ModaRecords is offline
Default Direct monitor
Does PT M powered have a direct moniting option so when you are say recording a vocal there is no latency? thx
Old 06-05-2006, 12:03 PM
Avi Bortnick Avi Bortnick is offline
Default Re: Direct monitor
Yes and no. Pro Tools does not really have this feature. However, many (maybe all?) M-audio boxes have a direct monitoring function.
I have a Fast Track Pro, which does have direct monitoring. Unfortunately, with Pro Tools, when you record enable a track, you have to specify an output, which automatically blends in the no latency direct sound, with the output (with latency) from Pro Tools. The way around this is to route the record-enabled track to stereo outputs 3/4, rather than 1/2. The drag is that when you want to listen back to the track you just recorded you have to switch track outputs to 1/2. So it's an extra (and stupid) step. I wish it were set up so that when recording, ouput were muted, but when playing back, output is unmuted.
The drag with my "solution" is that punching in is difficult, because you can't hear the previously recorded audio on the track your punching in to.
I wish people at Digi would actually look at how people work and build this "disable output on record" feature in.
In my opinion, no amount of latency is tollerable except for the mushiest keyboard pads.
Avi
Old 06-06-2006, 06:03 PM
buctayla buctayla is offline
I find that there is hardly any latency at 128 samples
Old 06-07-2006, 08:31 AM
B-Grade B-Grade is offline
it gets a little more noticable doing portamentos with your voice. If I say nothing to the performer, they usually don't say anything. But those that notice...I have to switch over to the Panel for monitoring and it is a pain. Digi should do like an ASIO Diect monitoring thing for M-Audio.
Mac Pro Rack - Ventura
PT 23.12
HDX - MTRX Studio
Mac M2 13" Air in the field
Old 06-09-2006, 02:52 PM
messenger messenger is offline
here here!
buffers set to 128 and the latency is only managable (at best) because I've become accustomed to it. Others who are not find it distracting, ESPECIALLY with electric drums (dont bash em until you've tried em... the Roland TD-12, anyways...)
I think Pro Tools should get on top of this ASAP
matt
Old 07-22-2006, 03:57 AM
blueintheface blueintheface is offline
Avi
I just wanted to check that this is still the case?
I really need zero-effort zero-latency record-monitoring. Auto-switching as the above quote suggests - or "disable output on record".
I can't be bothered faffing around switching tracks on and off to avoid monitoring latency when recording.
I just assumed - I know, silly me - that PT would have this thing sorted, being such an industry standard.
I'm looking for something easy as I'm licking my wounds after a couple of years with an 01X and thought the ProjectMix would be the way to go.
Ideas?
Old 07-23-2006, 02:18 AM
Seriously though, how hard is it to hit the mute button on a track and route it's output to the cans from within the m-aduio control panel?
It just shouldn't be necessary.
What happens if I want to drop in on a track. Let me just mute it and re-route at the same time?
Do I have a point or what?
Old 07-23-2006, 08:08 AM
Ben Jenssen's Avatar
Its there:
Prefs: "Link/unlink record/play fader" (or something to that effect, dont have my PT in front of me.) When in rec mode, set the fader to -inf. When in play, set the fader up. Then, when you toggle the "R", the fader switches position. Also check "Auto input monitor".
IHTH.
Old 07-23-2006, 02:00 PM
IHTH.
Sounds perfect . . . thanks for that, Ben. Is this a recent feature addition - I'm wondering why a previous post didn't make use of it?
I re-iterate: zero-latency monitoring is a hardware issue
Yes, technically, you may consider zero-latency monitoring a hardware issue, but relatively few people can afford the luxury of a near-zero-latency ProTools HD set-up, and thus software manufacturers have devised ways for the rest of us to get round this issue - that is software working in conjunction with hardware, together as friends.
Steinberg's ASIO Direct monitoring, for example.
This is a thread in the M•Powered forum, after all, and the M•Powered interfaces do offer direct monitoring, and my question was whether ProTools accomodates this to provide with an integrated solution.
I didn't ask about PT HD nor do I want to do my drop-ins on a seperate track if that means I hear the previous track after I've dropped in - I'm happy pre-setting the drop points, so that should be OK?. I don't mind taking such 'destructive' decisions, but what (for me) really gets in the way of creativity/performance is unnecessary steps in the record/monitoring/drop-in process.
I would be very interested to know if Ben's answer satisfies Avi's post - it certainly sounds as if it should.
The drag with my "solution" is that punching in is difficult, because you can't hear the previously recorded audio on the track your punching in to. . . . . .
Avi
mbox3- can you direct monitor spdif inputs? n8tron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-11-2011 08:31 AM
Direct sound in one session/no direct in another? Balders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-12-2009 02:05 AM
Difference between Direct Monitor & Zero Latency valayah Pro Tools M-Powered (Win) 1 08-24-2006 07:56 PM
Direct Monitor in PTMP? HemifloWer Pro Tools M-Powered (Win) 3 10-17-2005 07:20 AM
Bounce To Disk or monitor out direct to ext. CDR? KennyD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 08-13-2001 07:24 PM
