Old 11-01-2021, 04:27 AM
BiggiT's Avatar
BiggiT BiggiT is offline
Default Neyr LtRt enc plugin crashese all PT sessions
OOfff.... 2021.10 PT
Neyr LtRt encoder plugin crashes all sessions..
SoundCode LtRt Tools no longer supported ?
Old 11-01-2021, 05:30 AM
its2loud its2loud is offline
Default Re: Neyr LtRt enc plugin crashese all PT sessions
Some help might be found here
http://duc.avid.com/showthread.php?t=417595
Old 11-01-2021, 08:38 AM
RossH RossH is offline
I don't use SoundCode LtRt, but I do use V-Mon from the same developer, and it's crashing all my sessions in 2021.10. Had to rollback to 2021.7.
Let us know if you hear from Neyrinck. Unfortunately my V-Mon problem stems from a Pro Tools problem which they aren't going to fix.
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's
Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer
Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo
Old 11-01-2021, 11:51 AM
DAPG DAPG is offline
Had this same problem. I downloaded and installed the latest version of SoundCode LtRt and it solved the crashing problem.
Roy Machado
Dallas Audio Post
Old 11-12-2021, 10:50 PM
jeremiahmoore jeremiahmoore is offline
Having similar issues here with Minnetonka surcode PLII.
…I think.
All of my 5.1 sessions crash PT on launch.
Have not yet been able to isolate 100% though.
Reverted to PT 2021.6 and all is OK.
Wondered if it might have to do with the new downmixing capability.
-jeremiah
Old 11-14-2021, 07:58 PM
npapaleo npapaleo is offline
Yup, Minnetonka is a no go on 2021.10. I don't think it's been updated in years so I'm not holding my breath for a quick fix. I used it as an opportunity to phase out LtRt from my standard workflow, if a client specifically requests LtRt I'll either shell out for Neyrink or try the Dolby Atmos tools (I'm told this is possible).
Old 11-15-2021, 12:06 PM
Thanks. I got a response from "telos support" which now supports Minnetonka plugins; the last supported OS for SurCode PL2 is 10.15.7 catalina, and they are apparently "discussing with engineering" about "how to move forward." M1 support is not announced.
I filed the following bug report with them:
"Surcode PL2 is crashes Pro Tools Ultimate 2021.10"
steps to replicate:
- open a session with SurCode PL2 instantiated on any track.
- Pro Tools hangs or unexpectedly quits.
- So far I'm seeing this 100%.
- I'm seeing this on two machines in Mojave / MacOS 10.14.6.
workaround:
- The workaround is to revert to an earlier version of Pro Tools.
-jeremiah
HTML code is On
LtRt AAX plugin antonis Post - Surround - Video 38 04-09-2018 06:12 AM
Plugin works in some sessions, not all Sage Maduin Windows 7 12-20-2012 06:53 PM
Neyrink LtRt plugin: container lululu Post - Surround - Video 4 08-12-2011 09:06 AM
Help! Sessions won't restore plugin settings... johnnybigmoose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-13-2010 05:20 PM
using plugin and mix settings across sessions samuelowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-17-2005 10:27 PM
