install ALL Updated Versions of ProTools?
Hi!
I'm using LE 6.8.1 at the moment. Now I downloaded the updates 7.0, 7.1, 7.1_cs8 and 7.1_cs9 Do I have to install 7.0 first to install 7.1 update? And please can you step by step explaining the uninstall-install-thing. I heard a lot of people are getting into trouble forcing this issue. Thanks a lot for your help!
Pentium D | Windows XP Professional SP 2 | Mbox2 | ProTools LE 6.8.1 |
Re: install ALL Updated Versions of ProTools?
You have to install 7.0 first. Then 7.1, then the cs'. Don't know about those "problems", never had them. But yea, 7.0 is an upgrade (required for...) 7.1 is an update to that.
Kryst |
Here is what I put in a previous post.
It worked fine for me. The thing to remember is that the previous version must be installed when you first run the update. It will tell you that a previous version is installed and it needs to be uninstalled. At that point (again this is only after you try to run the update with a previous version still installed) you then uninstall PT only. You must then reboot. Now run the update again. This time it should install. You need to go through this for each version you are updating. For example (from 6.7 to 6.9) or (from 6.9 to 7.0) and finally (from 7.0 to 7.1). This is my experience only and it sounds like some of you are having a problem with this process. I hope it works for you. I just wanted to chime in to tell you that it does work for some of us and is not necessarily that it does not work for everybody. CS updates don't seem to require the uninstall step. Good Luck
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
OK, thank both of you.
I'll give it a try on this weekende, cause it sounds like a time-intense "work" Thanks again, MrJakie
yes 7.0 then 7.1 which sucks as the first thing the 7.1 install does is remove 7.0 and not that it takes very long but dowloading both isnt enjoyable. anyway the results are worth the minor annoyence.
do you have have to install Quicktime if your not doing video work? |
You can save a little time by not installing any plug-ins or Command 8 drivers until the last upgrade. I'm not sure about Quicktime but I installed it anyways.
Obsidian Dragon
You can install 7.1 by itself without needing 7.0 (or at least I was able to)
RE ; Install of updated PT version 10.3.8 | Seafoam_Green | Windows | 3 | 12-27-2013 11:35 AM |
how to install 2 different versions of protools on one computer? | djkaz | Pro Tools TDM Systems (Mac) | 7 | 06-27-2009 01:36 AM |
how to install 2 different versions of protools on one computer? | djkaz | Pro Tools M-Powered (Mac) | 5 | 06-26-2009 11:14 PM |
How do I install two versions on Pro Tools on a Mac? | aVoreis | General Discussion | 1 | 03-21-2008 05:31 PM |
Can I install 2 different versions on the same computer? | bigpip | General Discussion | 2 | 10-06-2007 11:01 AM |
