Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 11-22-2013, 09:08 AM
ionactive ionactive is offline
Default Recommendation on Audio Interfaces (lots of inputs)
Hi All
I have PT 10 and 11 working well on a Windows 7 system. I have an MBox Pro three - also working well.
I use a lot of VI - however an increasing range of hardware synths. I have run out of inputs and therefore currently run some of them through a mix prior to the MBox Pro. This works, but means the mix is done independent of Pro Tools. Obviously you find that a number of tracks share the same input so you cannot mix independently in Pro Tools.
I know I could mute hardware and record actual audio (rather than midi / aux / instrument track) - however, what I am really after is lots more physical audio inputs into the interface.
Therefore, can anyone recommend an interface which is :
1) Firewire
2) Has a substantial increase in inputs over the MBox.
3) Is compatible with Pro Tools 11.
At the end of the day I want to be able to use more instrument (midi / aux) tracks in Pro Tools and control the level etc of more hardware in real time.
Any ideas - let us say that price at this point is no issue (probably will be!).
thanks in advance
rgs
Mark
Old 11-22-2013, 09:38 AM
Craig F Craig F is offline
Default Re: Recommendation on Audio Interfaces (lots of inputs)
Some FW ideas
UA Apollo 16
RME Fireface 800
Focusrite Saffire Pro 40
Ethernet idea
Focusrite RedNet3
Thank you,
Craig
Old 11-22-2013, 10:50 AM
Originally Posted by Craig F View Post
Some FW ideas
UA Apollo 16
RME Fireface 800
Ethernet idea
Focusrite RedNet3
All those, and don't forget the "cheap" route of a used 003R and a decent lightpipe preamp. That can get you 16 inputs for as little as $500. Of course, the Apollo gets you UAD processing(very nice). The Saffire can also take a lightpipe preamp for 8 more inputs. The Saffire LS56 can go to 24 with a pair of lightpipe preamps. Lots of options, depending on how much you can afford
Old 11-22-2013, 10:40 PM
Thanks indeed. Will look into those options.
I sometimes get confused by advertised number of I/O and what I can physically see. Generally most of my hardware is stereo - so I want a pair of inputs for each one. 16 I/O (i.e. physical connections) gives me 8 pairs to work with. I am amazed there appears to be few devices with this many (the common appears to be up to 8, with some shared between mic and DI duties).
Old 11-24-2013, 07:35 PM
Most of what's available these days does seem to fit that 8 channel picture, with more inputs available, but requiring more hardware to be purchased. The Apollo 16 is ready to go, with 16 inputs, but they are all line level(no mic preamps). The other options all have a lightpipe input, and all you need to get the magic 16 is an 8 channel lightpipe preamp. These start at around $200 for the little Behringer ADA8000, on up to close to $3K for the Focusrite ISA-828 w/digital card. My recommendation for cheap is the Behringer(or slightly more for the new Behringer ADA8200 with the Midas-designed preamps) and for best value, I like the Focusrite OctoPre Mk II Dynamic, followed by the Presonus D8
Old 11-24-2013, 10:23 PM
persuader's Avatar
persuader persuader is offline
RME fireface ufx. Very stable drivers.
Sent from my Nexus 4 using Tapatalk
Old 11-25-2013, 06:11 AM
junkgear's Avatar
junkgear junkgear is offline
I've had good luck with the Presonus Firestudio Project.
It has 8 pres, but you can buy additional units and daisy chain them together to fit your needs.
Will
System Details
Old 11-25-2013, 06:42 AM
JoelG's Avatar
JoelG JoelG is offline
I've been happy with my M-Audio Pro Fire 2626, although driver development can be a bit slow at times. It does give you 8 line/mic inputs and 2 ADAT inputs (so you could add 2 of those Behringer ADAT pre's Albee was talking about).
If I where in the market right now, I'd get the Motu 896mk3 personally. USB and Firewire, 2 ADAT, 8 pre's. I have no hands on with it though, so that's just by reading about it.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 11-25-2013, 07:05 AM
Emcha_audio's Avatar
I'm presently using a Liquid saffire 56 and a Saffire pro 40. will be updating this rig soon as a portable right though (since I'm planning on a total change of gear in the studio). At which point I will be dropping the pro 40 and going either with 2 additional octopre dynamic mk2, or 2 additional liquid saffire 56 (controlled with two smallish laptops to change the liquid channel on the fly) through the additional adat in/out of the main unit. Both setup would give me 24 in's and 24 outs. The only thing I hate in the designs of the pro 40 and the non dynamic octopre's is that they have 2 inputs set on the front without having the same 2 inputs available behind. Meaning that when you have a rig setup with patchbays, you still have to have cables pass in front of the rig.. stupid designs decision.. they could have mirrored two inputs at the back and enabled a cleaner and easier connection scheme.
Manny.
Wave-T.com
Recommendation for new audio interface georgepeter FireWire & USB Audio Interfaces (Mac) 7 08-15-2013 09:50 AM
PT10 with multiple MOTU interfaces - can't get all inputs in I/O Borgbilly macOS 3 08-30-2012 07:05 AM
Need a software recommendation for burning audio CDs DonaldM General Discussion 3 11-04-2010 04:40 PM
Audio Interfaces barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-15-2010 05:53 AM
How do studios archive lots of audio data? Daniel Wellman General Discussion 6 04-01-2002 05:57 PM
