Help, PTLE does not respond after session load (session lost?)
The recording session I did today does not open anymore in PTLE 8.0.3cs2. I can start PT, select the session file, it loads but as soon as the edit window appears, PT stops responding. I have to reboot to continue working with my computer. Older sessions load fine, just the last ones do not. Are there any keys I can press during load to disable plugins or whatnot to narrow the cause for this? Any tips?
Re: Help, PTLE does not respond after session load (session lost?)
Hold shift key while loading session should deactivate plugz.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
Yo! That seemed to work. I have no idea what the problem was, but I loaded the session while holding the shift-key and all plugins have been deactivated. I randomly reactivated them, saved a few times to different file names, closed and reopened the session and now everything is back to normal.
The bummer is that I don't know what the problem was, so it could happen any time again ;-(. |
Open the original project (without plugs) and open plugs one at a time. Then check to see if you have all the upgrades.
www.rickqueststudio.com |
protools 11.01 close session crashes on load next session | eddie lamb | Pro Tools 11 | 2 | 09-07-2013 01:51 AM |
AIR Mini Grand doesn't respond after re-opening session | morei | Virtual Instruments | 7 | 12-06-2012 02:08 AM |
When loading previous session, plug-ins won't respond! | fightingcory | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-02-2009 10:16 PM |
Session will not load | SpillingSounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-27-2005 02:28 PM |
OS X 10.3.2 PTLE 6.0 Digi 001 Won't Load Session | Peulock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-31-2004 10:39 AM |
