Hi all -
I just started working at a new facility and I'm having an issue with the output levels from Pro Tools not being even. Here is the necessary tech info: Soundcraft Ghost console Mac Pro (10.6.7) 2x2.66 GHz Dual Core Intel Xeon 16 GB 667 MHz DDR2 RAM Pro Tools HD 8.04 with 2x192 Interfaces Output 1 from Pro Tools is coming in at roughly 2-3 db louder than Output 2. This occurs both in Pro Tools and if I play something through iTunes or anything else requiring the CoreAudio Manager. When I switch to Outputs 3-4 both in Pro Tools and setting Audio MIDI Setup to Output Streams 3-4 (for computer playback), the signals are even. I have ensured that no signal is being doubled from Channel 1 on the Ghost and that everything is either zeroed or at unity. I can compensate by lowering the output of Channel 1 on the console, but that doesn't change the fact that the meter bridge is still reading the left channel hotter than the right. This has been an issue since I started here and I cannot, for the life of me, figure this out. I am fairly positive this is an issue from Pro Tools, but cannot trace it. Does anyone have any suggestions? Thank you in advance. |
Try changing the input 1 cable. Or just swap 1 and 2 cables and see if the problem follows.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I swapped cables and yes, the problem follows.
So the meter bridge on the 192 is showing a higher level? I don't have a 192 but can you do any internal trims?
This is the PT9 forum. You may have better luck going to the HD forum. But I did find this in the set-up drive:
Each of the analog channels in the 192 I/O has two Input Trims, labeled A and B, for precisely calibrating and switching levels. You can select Input Trim A or B on a chan- nel-by-channel basis. Refer to the 192 I/O Guide for information on setting the rear panel trims.
Yessir you are correct. I just checked into this and found the same document online that you are referring to. Time to bust out my meter and do some calibration!
Thank you kindly for your assistance ![]() |
Hold on before you do anything: you said the fault follows the cable, therefore your fault IS the cable.
System Details: Macbook Pro 17" OS 10.7.5 PT 10.0 8 gig ram FW Drives (Multiple) eSATA Drives (Multiple) [email protected] |
I think he just swapped one end. He didn't replace the cable: it remained connected at the 192 end.
Matching input levels on Venue and PT HD | dperry23 | VENUE Live Sound Systems | 1 | 09-18-2009 01:43 AM |
Help Matching Effects Levels For Mixing | Keith Moore | Pro Tools TDM Systems (Mac) | 5 | 05-31-2009 12:00 PM |
Pro Tools Output Levels - Please Help! | theflash | Pro Tools TDM Systems (Mac) | 3 | 05-12-2006 02:06 AM |
matching input and output levels | ira ostrowski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-09-2003 02:25 PM |
Matching Analog Input Levels On Audiomedia III | applaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-03-2002 07:36 AM |
