Old 11-11-2024, 03:12 PM
basslik's Avatar
basslik basslik is offline
Default Tempo song change
Good day everyone.
I never used the algorithm to slow down tracks before.
I have 8 drums,bass,and two mono guitar tracks I need to slow down slightly to accommodate a singers abilities.
Anyhow, should I use certain algorithm for each track, or just select all tracks and slow them all down at once ?, thanks.
MAC PRO 2010 5,1 3.46hex 128ram -CONTAINERS / SEQUOIA 15.5 / MONTEREY 12.7.6 & SONOMA 14.6.1 - PT 2025.6 / 003 RACK BLA SIGNATURE MOD / DIGI 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 11-11-2024, 09:09 PM
Top Jimmy's Avatar
Default Re: Tempo song change
If you’re referring to using elastic audio, then yes you should choose the appropriate algorithm for each track. The easy way to do this is to enable elastic audio in each track, put the tracks in ticks mode and then change the tempo on the ruler.
James Cadwallader
Old 11-12-2024, 04:57 AM
tope d's Avatar
tope d tope d is online now
same thing I would usually do
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 11-12-2024, 05:14 PM
basslik's Avatar
Thank you both. Okay, I do that for sure. use the grid line to slow down in increments. thank you both very much.
Change song tempo PT 12 jwilkers Pro Tools 12 12 04-18-2017 12:19 PM
How do I change Tempo's throughtout a song in PT 8? Postkill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-01-2011 11:15 PM
tempo change of song? Roy Stanton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-14-2008 02:43 PM
Can I change the tempo of my song after recording? sethbrand General Discussion 2 02-01-2006 12:29 PM
How to change tempo mid-song? MinhSomeLoseSome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-19-2003 05:33 PM
