Old 08-03-2010, 08:38 AM
BrendanClace BrendanClace is offline
Default Click Reversed?
Hey guys,
Random problem last night doing ghost tracks for the band I'm working with. The click timing is reversed. What I mean is that, if I switch it to 1/8 notes, it plays every 1/2 note, and if I switch it to 1/16 notes, it plays at 1/1 notes. I'm not sure if there is a setting, or if it's just PT or what....any thoughts? I mean, its fine because I needed 1/8 notes so I just switched it to 1/2.....but I shouldn't have to do that....I should be able to set it to 1/8 and have it click at 1/8......
Any help is greatly appreciated!
AMD Phenom II X4 965BE @ 3.9GHz
ASUS M4A78T-E (AMD 790GX)
4GB G-Skill DDR3 1333
ATI HD5870 1GB
Windows 7 x64
Mbox 2
Pro Tools 8.0.4cs2
Old 08-03-2010, 08:58 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Click Reversed?
Really no help for it; thatz the way it works for som odd reason...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 08-03-2010, 09:05 AM
It worked with 7.4 AFAIK..... :S
ATI HD5870 1GB
Windows 7 x64
Mbox 2
Pro Tools 8.0.4cs2
Old 08-03-2010, 09:08 AM
Always seemed to be backwards to me but then it's been a while since I've been on 7.4 so it may hav been; but nevertheless, it's jacked now
I'm used to it tho myself...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 08-03-2010, 09:21 AM
How can such an obvious flaw be just "passed over" by Avid? Like, IMHO this makes them look incompetent because it's so blatantly obvious that it's supposed to be the other way around....no matter what way you look at it...it's wrong....I mean its not detrimental to the workflow, but definitely a PITA.
ATI HD5870 1GB
Windows 7 x64
Mbox 2
Pro Tools 8.0.4cs2
Old 08-03-2010, 09:28 AM
spkguitar's Avatar
How, exactly, are you setting the value of the click? Something definitely doesn't sound right about that.
It sounds like you might be confusing Tempo Resolution with Click Resolution.
Old 08-03-2010, 09:32 AM
Changing the tempo of the song, and setting the note value in there. I change the grid for what i need it depending on the section of the song.
ATI HD5870 1GB
Windows 7 x64
Mbox 2
Pro Tools 8.0.4cs2
Old 08-03-2010, 09:36 AM
spkguitar's Avatar
Yeah, you're confusing tempo resolution, with click resolution.
Try changing the meter of the song, but don't actually change the meter, change the click resolution from within there.
Old 08-03-2010, 09:42 AM
OMG seriously?
Wow....I completely effed up....
Thanks guys!
ATI HD5870 1GB
Windows 7 x64
Mbox 2
Pro Tools 8.0.4cs2
Old 08-03-2010, 10:03 AM
spkguitar's Avatar
Yeah...
Tempo Resolution is basically the BPM of the song. It sets the beat note value. So if you set the beat note value to 1/8, and the click resolution is still set to 1/4, the click will slow down (as it should).
However, if you set the click resolution instead, you will actually be changing just the click resolution. 1/4 = one click every 1/4 note. 1/8 = one click every 1/8 note.
See, they really aren't incompetent; they just want you to read the manual...
pan settings are reversed! help? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-24-2024 09:55 PM
OT: Bootcamp...reversed!!!??? mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 04-16-2009 02:24 PM
Pan Encoders Reversed on D-Command teacherman ICON & C|24 2 09-25-2007 04:50 PM
Outputs reversed Sparks Pro Tools TDM Systems (Mac) 1 07-22-2003 03:27 PM
mic inputs reversed Adam Denston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-23-2002 09:33 AM
