Unsupported Audio Buffer Size Error ProTools 11 Win10
Hi, I am trying to open a newly downloaded copy of ProTools 11.3 on my computer running Windows 10 and am running into the following error:
"Your audio device is configured with an unsupported audio buffer size. Please select one of the following supported buffer sizes in the device control panel: 32, 64, 128, 256, 512, 1024, 2048." I opened audio settings in the windows control panel but there are no options to change buffer size. Clicking OK or More Info on this error message causes ProTools to close, and there is no way to access ProTools buffer size settings. How do I fix this? I have installed ProTools 11 under an iLok License which I was already using on my Mac. Everything else seems to be in order with installation except for this error. |
Re: Unsupported Audio Buffer Size Error ProTools 11 Win10
It sounds like you're trying to use your audio interface for both Windows and PT and that shouldn't be done. After you've de-selected for system use your audio interface in Windows Control Panel hold down the 'n' key on your computer keyboard when starting PT and you'll be able to select your audio interface.
Also make sure to turn off any power savings measures in Windows Control Panel for not only the computer but the USB ports as well. |
And your audio interface needs to have its buffer set to one that Pro tools supports, at least my RME interface does.
Unsupported audio buffer size in device control panel | TheVRsNo$ | Windows | 27 | 12-09-2019 06:28 AM |
Pro Tools 12 "Your audio device is configured with an unsupported audio buffer size" | Mirela | Windows | 0 | 01-08-2016 05:39 AM |
Pro Tools 10.3.6 won't launch, unsupported buffer size error with ProFire2626 | LarrySmileyEL | Pro Tools 10 | 7 | 01-10-2015 12:55 AM |
FYI: PT 10.3.3 complains about unsupported buffer size 2048 | Niilo Nuori | Windows | 0 | 02-22-2013 03:43 PM |
ProTools won't launch; unsupported buffer size | DarylG | Windows | 3 | 02-23-2011 08:07 AM |
