Old 11-27-2022, 01:34 PM
Fritz Fritz is offline
Default structure crashes 1 incidence
and crashes PT as well.
anyone else?
2022.9
Mini 2018, Big Sur, 64G Ram
"Do not fear mistakes. There are none."
Miles Davis
Old 11-27-2022, 01:51 PM
Default Re: structure crashes 1 incidence
Which version of structure?
Old 11-27-2022, 01:56 PM
Free - v1.5.10.82e5fd3. Just installed today from my acct page.
Did I take the wrong one?
Miles Davis
Old 11-27-2022, 02:32 PM
Ben Jenssen's Avatar
I just installed AIR Structure 2.0.11, latest version. Got it on sale for $10(!). Suited me fine, because I received a session with Structure.
I have barely opened it, and it seems to work - only thing is what seems to be a graphic glitch; the whole Avid-part of the plugin window (with presets saving and so on) is white. I close the plugin window and open it again, and its OK. It's old. Plays fine, though.
You should check the AIR website for latest version.
Added: Ah, I see you added that your talking 'free' version. Then I don't know, I've had that forever, using it occasionally, never had a problem
Old 11-27-2022, 02:37 PM
thanks. dl'g now. hopefully that'll fix it
Miles Davis
Old 11-27-2022, 04:30 PM
unkJE's Avatar
unkJE unkJE is offline
I just installed AIR Structure 2.0.11, latest version ... it seems to work - only thing is what seems to be a graphic glitch; the whole Avid-part of the plugin window (with presets saving and so on) is white. I close the plugin window and open it again, and its OK. It's old. Plays fine, though.
Nice workaround, as Structure 2 - macOS Catalina, Big Sur & Monterey Compatible (M1 Mac not supported)
https://help.pluginboutique.com/hc/e...-Download-Area
Something to remember, before installing your next Pro Tools update:
remove Structure 2 (Full version) from your Plug-Ins Folder and save it elsewhere, as installing AIR Instruments (included with Pro Tools) adds Structure Free, which used to delete Structure Full.
Doubt whether this issue has been fixed yet, so I install AIR Instruments, delete Structure Free, then replace it with my (quarantined) Structure Full.
Old 11-27-2022, 04:45 PM
Thanx for the info. I hope I can remember it at the next crossroads. But then, my plan is to reinstate and get current when PT gets native and reasonably stable on apple silicon, and I guess Structure won't make it thru the night.
Old 11-27-2022, 07:40 PM
dl'd 2.07 for Mac OS which was all I could find.
crashed as before both the VI and PT 2022.9.
Sent them a tech support request. But I'm sure I can find a Structure alternative for as often as I might use it.
Miles Davis
Old 11-27-2022, 08:22 PM
unkJE's Avatar
Originally Posted by Fritz View Post
dl'd 2.07 for Mac OS ...
Completely uninstall 2.07
Run the free CCleaner for Mac then hit the 'Registry' button in the LH column.
Hit the 'Scan for Issues' button - once 100% done - hit the 'Review selected Issues' button - save changes when prompted by hitting the 'Yes' button to back up the Registry
Repeat 'Scan for Issues' until no more Issues are found
Hit 'Fix All Selected Issues' button then the 'Close' button
Exit CCleaner and restart computer
Download and install:
Structure_2.0.11.21000_Setup_macOS-GM
Restart computer
Launch Pro Tools
Old 11-28-2022, 05:48 AM
thanks unkJE.
I didn't follow your method exactly as I don't know that CCleaner has cleaned up it's own act where the Mac OS is concerned.
But I did trash AIR Music Tech completely.
Then AppCleaner, Disk 1st Aid, & Onyx before a restart.
Installed Structure from your link.
DFA again and restarted.
Launched PT.
Structure loaded and loaded it's various bits and had no graphic issues as indicated above.
Time will tell.
Now to try and get my head around it. Just really looking to replace a snare and kick in a track I have with my sample.
Miles Davis
Structure crashes PT when loading EXS patches Hanswurstlsepp Virtual Instruments 16 09-22-2015 01:04 AM
Structure 1.1 crashes PT 8.0.4 when click browser audiojavi Virtual Instruments 0 08-29-2010 06:41 PM
Structure crashes when trying to load Gigasampler patches lkingston Virtual Instruments 3 05-17-2010 02:48 PM
8.0.3 on SL: Structure Free crashes PT fenderrocker Virtual Instruments 10 04-08-2010 08:32 AM
Structure crashes PT8 when loading Hercules98 Virtual Instruments 2 04-08-2009 09:08 AM
