Old 03-30-2024, 10:28 PM
tonyespinoza tonyespinoza is offline
Default Anyone running HD I/O's with HD PCI?
I want to access some old stuff from when I was running an HD/TDM system. I have a Process card that passes DigiTest under a PT TDM 6.4 install on Panther 10.3.2 as well as PT 7 HD install on Tiger 10.4.11 (separate hard drives).
So far so good... but I was hoping to use one of my HD I/O's with this system as I haven't been able to find any indication that it wouldn't work since it's DigiLink. DigiTest shows it as a 192 class interface but says the firmware version is "0" so I'm thinking this might be the issue.
Curious if anyone has run an HD I/O with an old PT HD system like this or if anyone can share any thoughts on how to get the firmware updated on the HD I/O... I could press the update firmware button, but I'm a little nervous about making a bigger mess if this isn't something that isn't supposed to work anyway...
At this point with the HD I/O connected both DigiTest and PT will "Unexpectedly quit" and not launch. If I remove the HD I/O, DigiTest works fine and PT complains there is no interface connected to the first HD card...
Email is best: tony@sfsoundworks.com
Old 03-30-2024, 11:39 PM
Default Re: Anyone running HD I/O's with HD PCI?
I thought the minimum version of Pro Tools that worked with HD I/O was Pro Tools HD 8.1. Pro Tools has to know how to manage the HD I/O box. I would not assume your setup would work.
Dual Boot 10.6 running 8HD & 10.7 running 10HD STL Audio macOS 3 04-14-2012 05:38 AM
Im running PT8 on WIN7(running off of VMWARE) Conolly10 Windows 2 12-11-2010 06:38 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 07:34 PM
Running Pro Tools LE 8 on XP and running 2 monitors JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-31-2010 07:38 PM
Running PTLE for Win on an Intel Mac running XP? postmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-27-2006 11:08 AM
