Old 03-03-2010, 05:10 PM
Paul_Cantor Paul_Cantor is offline
Default Automation Continuation After Record Stop
In older versions of Pro Tools I would ordinarily be able to enable automation on a track, do whatever I needed to do while in "write" mode, and when I stopped writing, whatever I left off with would continue...
for example, say I was doing mutes on a drum track... when I got to bar 9 I would unmute a kick... then I could stop playback and the rest of the track's automation would continue along, unmuted.
That seems to be reversed in Pro Tools 8. I have to go into each track and unmute in the automation edit. Major pain.
Is there any way to switch this back?
Any help would be deeply appreciated.
Old 03-03-2010, 05:19 PM
rqstudio rqstudio is offline
Default Re: Automation Continuation After Record Stop
You must have written the mute move so it keeps switching on you. on the left side of you edit window button you can view waveform, volume, and mute info. Click that and delete your move.
Old 03-03-2010, 05:24 PM
Yes I know what you're referring to. I'm trying to avoid having to go into each and every track and do that.
All I want to do is click Unmute in automation write mode and have the rest of the track continue along unmuted. As soon as I click stop on the transport, no matter what track I'm on- and this has been this way since I got Pro Tools 8- the tracks goes back to being muted. It's like I have to sit there and write 5 minutes of automation
To be clear, Pro Tools does record my automation. It's not erasing it or anything, just that when I clock stop the rest of the track data defaults to muted
Old 03-03-2010, 06:35 PM
I'm still not sure if just one track or all of them are reverting to mute, or if your playhead is going back to the spot where mute automation has been written.
Try this, click the group all, then click alt and find that mute option in the waveform box I was talking about. Click and Drag your cursor across the entire song. Everything should be highlighted. (MAKE SURE YOU'RE IN MUTE EDIT) Then simply hit delete.
If you're having problems with the song continuing from that spot after you hit stop, check the 'playback follow edit' option.
Old 03-06-2010, 09:35 AM
Thank you, I will try those things. Was kinda trying to avoid having to go in and alt click and select everything but maybe playback follow edit option is what's doing it
Need to stop automation from following playlist. sevan Pro Tools TDM Systems (Mac) 2 07-15-2008 07:48 AM
Cannot record / stop button jglover51 Pro Tools M-Powered (Win) 0 03-29-2008 04:20 PM
cannot record and cannot stop play x9blade Pro Tools TDM Systems (Mac) 2 02-20-2006 04:52 PM
Rapid start/stop deletes automation Burmansound Pro Tools TDM Systems (Mac) 4 07-25-2005 09:48 AM
Record Stop Effect snoopy Tips & Tricks 7 11-01-2002 05:02 PM
