PT 12 loses hardware set-up
I have a problem I periodically encounter: PT loses the hardware set-up. For example, I can be working on several projects in day, experiencing no technical problems. Then, after shutting down for a break and resuming work, I get the error message “ Digidesign card not installed.” (I’m using a Silverface Apollo interface firewire system. It is showing it’s age, but it does everything I want it to.)
If I attempt to start a project, I can’t run set-up- all options are grayed out. I therefore have to exit Pro Tools, shut the system down, re-boot the system, and re-start Pro Tools. If I go to set-up before loading a project, I can then find and select Universal Audio hardware, select it, and resume work. An annoyance, to be sure. I can have this occur several times in a day, then go for weeks without it happening again. What’s up, and how do I fix it? Last edited by mickeyrouse; 08-10-2021 at 07:05 PM. |
Re: PT 12 loses hardware set-up
Replace the firewire cable and try another firewire port would be my first 2 things to try(and don't do this with everything powered ON....just to be safe)
Ahh ha!!
That may well be it. |
S1 loses connection | Jazzbass56 | Avid S1, S3, Dock and Control App | 24 | 01-30-2020 10:18 AM |
OMF loses all it's audio. (PT HD OSX) | Rob_H | Post - Surround - Video | 13 | 11-01-2007 08:49 AM |
PT loses regions | Larbabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-11-2002 04:32 PM |
PT 5 loses avi's on mac | robi3 | Pro Tools TDM Systems (Mac) | 2 | 12-01-2000 11:14 AM |
5.0.1 still loses faders | bootman | ProControl, Control|24, Command|8 | 1 | 06-29-2000 03:46 PM |
