Old 07-04-2012, 08:44 PM
Anibal Anibal is offline
Default "setting up midi" takes forever at boot up
just installed PT10 and I love it, it definitely sound better than 9...
when I'm booting up, the "setting up midi" window stays frozen for a good 2 minutes and then it's fine... any clues?
thanks
PT 2018 HDX 1
Mac Pro Westmere 12 core 3.46 OSX 10.12.5
64 gig ram
Old 07-04-2012, 08:57 PM
Default Re: "setting up midi" takes forever at boot up
and I just realize that I have no midi...
PT 2018 HDX 1
64 gig ram
Old 07-04-2012, 10:26 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
It sounds better ??? Can u hear the extra 8 bits on the audio files ??? ;->
Daniel
Old 07-04-2012, 10:57 PM
yes, it does sound better... bigger... you'll see
PT 2018 HDX 1
64 gig ram
Old 07-05-2012, 05:41 AM
Kasper Kasper is offline
thanks
Could be a corrupt MIDI config.
Throw away your MIDI configuration, then recreate it (quit PT first)
It's probably here - ~/Library/Audio/MIDI Configurations/
kasper
Old 07-05-2012, 06:28 AM
Hanswurstlsepp Hanswurstlsepp is offline
More analogue
... sorry couldn't resist
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2022.9  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 07-05-2012, 01:54 PM
YYR123's Avatar
Personally holding out till PT11x64 - when who knows but i will most likely pass on 10
Daniel
Old 07-05-2012, 02:39 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
I stuck with 9 for the longest time, but since 10.2 and the problems became less a PT software issue and more "individual setup" issues... I upgraded all my studios and edit suites... Not one issue so far, infact I have had positive feedback from the engineers about how much smoother it is running.
Could be a driver issue... might get hung up communicating to your midi device... have you tried uninstalling the midi driver? Have you installed the latest PT midi driver?
Scroll down to Midi drivers:
http://avid.force.com/pkb/articles/e...p;DocType=1450
Old 07-06-2012, 08:04 AM
thank you Jason, tried everything, no luck... still doesn't see my MIDI I/O...
and AVID is closed till Monday, great support...
PT 2018 HDX 1
64 gig ram
Old 07-06-2012, 08:51 AM
Interesting... Try a total preference trash.... see if it pushes through the midi config at start up faster.
http://www.youtube.com/watch?v=Mj2fJHOz8GA
"creating DAE objects" takes forever... Anibal macOS 3 04-16-2013 02:24 PM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 03:42 PM
PT 10 Hangs on Pgm. Boot at "Setting up MIDI" billborg Pro Tools 10 4 10-26-2011 11:11 AM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
"Save Copy In" takes forever mbcaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-01-2008 11:38 AM
