Old 10-01-2011, 09:52 AM
peterle peterle is offline
Default Relink takes forever...PT 9.05
same problem with two projects:
automatic relink needs hours wih no success and blocks PT.
even when directing PT onliest to the correct folder
(on an internal HD )
automatic relinking takes forever ,
i have to manually relink file for file
which works then, but is PITA if i have a lot of files.
The session came from a PT 6.4.1 mix rig on 10.3.9
BWav , PC compatibility checked
via an FAT32 formatted USB device
The other Session is coming from an AVID AAF(newer ones)
and contains an OMFI Files Folder where scanning and
relinking also blocks PT complete for hours while scanning.
PT reacts sluggish and playback is impossible.
This session is on an FW 800 HFS drive.
any ideas?
PT 9.05
10.6.8 , Aggregate device ,
5 HD à 1,5 TB
Nehalem 8-core , 8 GB
foley artist , soundeditor
Old 10-01-2011, 11:24 AM
Top Jimmy's Avatar
Default Re: Relink takes forever...PT 9.05
Originally Posted by peterle View Post
any ideas?
Don't try to automatically find and relink. You've already discovered that manual relinking is much quicker. If all your media files are in the same location, you should be able to find the links for all of them and relink them all at once.
James Cadwallader
Mac Studio, 64GB RAM, 1 TB SSD, Glyph 2TB USB3 HDD, OWC drive dock, Mac OS Monterey 12.6.2
Pro Tools Ultimate 2022.12, HD Native, Focusrite Red 8Pre
PT 10 takes forever to start up DJYoutubeDJ Pro Tools 10 3 06-28-2013 01:39 PM
Protools 9 takes forever to record! fallenidols macOS 2 07-04-2011 11:17 AM
Powerbook takes forever to boot with PT 6.9 sukks2bu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-23-2006 08:45 AM
Starting takes forever Kiwi Bruce 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-21-2004 07:01 PM
