fast way to lengthen intro
I am on the final stages of a house track I made. It contains vocals, drums, and synths, and some recorded instruments. All midi synths, and drums, were bounced to audio in pro tools.
I'd like to lengthen the intro to the song before the vocals come in. I feel like they come in too fast. What would be an efficient way of doing this? I'm thinking there has to be some way I can highlight the tracks, and then use a key command to double the length of the intro. Thanks for the help in advance. |
Re: fast way to lengthen intro
Make a selection in grid mode of however many bars you want to copy forward and insert edit point/break the regions. Then control+option+command click those regions with the grabber and they will duplicate forward. Done :)
Enable the ALL group>select Grid mode(be in Bars:Beats) >highlight/select the opening bars to repeat>select SHUFFLE mode>Ctrl-d(this will duplicate the highlighted section and copy it after the current selection, and push the rest of the song back to fit the added measures. Get out of SHUFFLE and disable the ALL group(so you don't screw things up). Now you can freely adjust edge boundaries to smooth any transitions
what is insert/edit point?
Lengthen recording | FECUTTINGEDGE | Getting Started | 3 | 01-25-2015 01:24 PM |
How to add an intro? | Sonic Blue Meanie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2010 07:40 AM |
Intro and some trouble | PT_n00b | Pro Tools M-Powered (Win) | 5 | 01-30-2009 05:49 PM |
How to lengthen a MIDI Region without TCE? | Dizzi45Z | Tips & Tricks | 8 | 01-03-2009 08:42 PM |
Strech or lengthen an audio note? | rqstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-15-2007 11:01 AM |
